D
David Nebenzahl
OK, another potential project: re-jiggering the mike for my Sony Walkman
Professional cassette recorder to use phantom power.
I have the WM-D6C Walkman "Professional" recorder and a Sony ECM-737
stereo microphone. The rig still makes very nice recordings. (No, I
don't usually use it for music, and I'm not pushing cassette as the
ultimate recording medium.)
The annoying thing about it is that while the microphone requires a
battery (a single AA cell), the recorder is apparently perfectly capable
of supplying power to the mike. The mike jack is marked "PLUG IN POWER",
which I suppose is Sony's way of identifying phantom power. (This may
not be "phantom power" in the sense of standard supply voltage, but
instead a proprietary Sony level.) I can't tell you how many times I've
had problems recording which turned out to be a low or dead battery in
the microphone. Probably my bad for not buying the next-better mike,
which I think did run on the recorder's power.
So I'm thinking I could modify the microphone to accept power from the
recorder, without modifying the recorder in any way. There are a few
things I don't know, however:
o The voltage of the power supplied by the recorder, which runs on 4 AA
cells. (48 volts? I'm guessing not, but who knows?)
o The configuration of the microphone jack. My mike uses a 3-conductor
plug, so what happens to the power contact in the jack?
o The wiring inside the mike and the difficulty of rewiring it (haven't
opened it up yet to look).
Anyone familiar at all with this equipment? Care to give some advice on
how to proceed?
Thanks in advance.
how to proceed?
Thanks in advance.
