ad9854 gets so hot while working, selution
Discussion in 'Electronic Design' started by payam, Nov 22, 2003.
  1. payam
    payam Guest
    according to ad9854 smd package get so hot
    any idea?
    thanks
  2. John Miles
    John Miles Guest
    Underclock it. I find that anything over 130 MHz or so is too hot for
    comfort. 200 MHz, the chip's rating, is China Syndrome territory.
    -- jm
  3. Either use a good 4-layer board with a large ground plane on ALL layers and
    plenty of vias UNDER the chip (each 1 to 1.5mm) to transfer the heat down to
    the bottom layer, or stick a small heatsink on the chip body. I've used
    these two techniques with a AD9852 with good results.
    Cheers,
    Robert Lacoste - ALCIOM : The mixed signals experts
    http://www.alciom.com
  4. maxfoo
    maxfoo Guest
    yeah, move to Siberia.
