AD8218 spice model is messed up.
Discussion in 'Electronic Design' started by [email protected], Jul 19, 2013.
  1. Guest
    Could someone verify for me that the AD8218 spice model is screwed up? The model and data sheet are here
    http://www.analog.com/en/specialty-amplifiers/current-sense-amplifiers/ad8218/products/product.html
    I'm just trying to reproduce Figure 35 in the datasheet. I'm using the circuit in Figure 34. I tied Vs and ENB to +IN because Ltspice doesn't like those pins floating. I set the shunt resistor to 0.02 ohms, the battery voltage to 24V, the reference to 1.25v and vary the Load from -5Amps to 5Amps in 0.05amp increments. My results show the part offsetting by twice the reference voltage instead of the reference voltage. I can reproduce the graph with the 1.25V reference but the datasheet shows a 2.5v reference. Here is thespice netlist.
    * C:\Projects\LIT\N48_TEC_Driver\simulation\AD8218Test.asc
    XU1 Vpos Vneg Vpos Vref Vpos 0 Vout AD8218
    V3 Vpos 0 24
    R2 Vneg Vpos 0.02
    V1 Vref 0 1.25
    I1 N001 0 1
    R1 Vneg N001 100
    ..include AD8218.cir
    ..dc I1 -5 5 0.05
    ..backanno
    ..end
  2. Guest
    I think line 129 is wrong
    E03 70 0 Value={ IF( V(ENB) == 0, V(65) + V(600) + .08 + V(ref), IF( V(ENB) != 0, V(65) + V(600) + V(ref), V(65) + V(600) )) }
    v(ref) is already added in on line 56. I think the line should read.
    E03 70 0 Value={ IF( V(ENB) == 0, V(65) + V(600) + .08, V(65) + V(600) ) }
    V(ENB) is either equal or not equal to zero, there is no third state and adding the V(ref) is redundant. Changing this line gives me the results I expect. But maybe I'm expecting the wrong results:)
  3. Guest
    Here is the ascii file.
    Version 4
    SHEET 1 1220 680
    WIRE 272 -48 240 -48
    WIRE 288 -48 272 -48
    WIRE -96 -16 -192 -16
    WIRE 64 -16 -16 -16
    WIRE 1072 16 976 16
    WIRE 1216 16 1072 16
    WIRE 976 112 976 16
    WIRE 64 128 64 -16
    WIRE 112 128 64 128
    WIRE 160 128 112 128
    WIRE 240 128 240 -48
    WIRE 288 128 288 -48
    WIRE -192 144 -192 -16
    WIRE 64 160 64 128
    WIRE 160 160 160 128
    WIRE 192 160 160 160
    WIRE 480 192 352 192
    WIRE 640 192 480 192
    WIRE 192 224 160 224
    WIRE 64 256 64 240
    WIRE 128 256 64 256
    WIRE 160 256 160 224
    WIRE 160 256 128 256
    WIRE 976 304 976 192
    WIRE -192 320 -192 224
    WIRE 240 352 240 256
    WIRE 352 352 240 352
    WIRE 464 352 352 352
    WIRE 64 384 64 256
    FLAG 288 256 0
    FLAG 64 464 0
    FLAG 480 192 Vout
    FLAG 112 128 Vneg
    FLAG 128 256 Vpos
    FLAG 976 304 0
    FLAG 1072 16 Vref
    FLAG 272 -48 Vpos
    FLAG 352 352 Vref
    FLAG -192 320 0
    SYMBOL Opamps\\AD8218 224 192 R0
    SYMATTR InstName U1
    SYMATTR SpiceModel AD8218
    SYMBOL voltage 64 368 R0
    WINDOW 123 0 0 Left 2
    WINDOW 39 0 0 Left 2
    SYMATTR InstName V3
    SYMATTR Value 24
    SYMBOL res 48 144 R0
    SYMATTR InstName R2
    SYMATTR Value 0.02
    SYMBOL voltage 976 96 R0
    SYMATTR InstName V1
    SYMATTR Value 2.50
    SYMBOL current -192 144 R0
    SYMATTR InstName I1
    SYMATTR Value 1
    SYMBOL res 0 -32 R90
    WINDOW 0 0 56 VBottom 2
    WINDOW 3 32 56 VTop 2
    SYMATTR InstName R1
    SYMATTR Value 100
    TEXT 456 432 Left 2 !.include AD8218.cir
    TEXT 448 392 Left 2 !.dc I1 -5 5 0.05
  4. Guest
    I don't have the actual part. I'm giving up on it and switching to the LT6016.
    Thanks for the help.
  5. Guest
    Here is the symbol.
    Version 4
    SymbolType CELL
    LINE Normal -32 72 124 0
    LINE Normal -32 -79 -32 72
    LINE Normal 124 0 -32 -79
    LINE Normal 64 -30 64 -60
    LINE Normal 64 27 64 61
    LINE Normal 16 50 16 60
    LINE Normal 16 -56 16 -60
    LINE Normal 16 -55 16 -56
    TEXT 71 -46 Left 2 +
    TEXT 75 46 Left 2 -
    TEXT -26 33 Left 2 +
    TEXT -26 -34 Left 2 -
    WINDOW 0 16 -80 Left 2
    SYMATTR SpiceModel
    SYMATTR Prefix X
    SYMATTR Description
    SYMATTR Value2
    SYMATTR SpiceLine
    SYMATTR SpiceLine2
    SYMATTR ModelFile
    PIN -32 32 NONE 0
    PINATTR PinName In+
    PINATTR SpiceOrder 1
    PIN -32 -32 NONE 0
    PINATTR PinName In-
    PINATTR SpiceOrder 2
    PIN 64 -64 NONE 0
    PINATTR PinName V+
    PINATTR SpiceOrder 3
    PIN 16 64 BOTTOM 15
    PINATTR PinName ref
    PINATTR SpiceOrder 4
    PIN 16 -64 TOP 15
    PINATTR PinName enb
    PINATTR SpiceOrder 5
    PIN 64 64 NONE 0
    PINATTR PinName V-
    PINATTR SpiceOrder 6
    PIN 128 0 NONE 0
    PINATTR PinName OUT
    PINATTR SpiceOrder 7
  6. Fred Abse
    Fred Abse Guest
    Doesn't make it work for me. With + and - inputs strapped, and a common
    mode stepped voltage applied, and a 2.5V Vref, offset is 2.5V, up to 5.6V
    applied, then jumps to 5.2V.
    Unused inputs grounded via 1T resistors, to make the solver happy.
    "if" syntax differs between Pspice and LTspice. That may have something to
    do with it.
    AD is a TI subsidiary, now. I wonder if that subcircuit behaves properly
    in TINA?
    If I get the time, I'll draw the subcircuit out as a schematic. I find
    that's the easiest way of debugging.
  7. Joerg
    Joerg Guest
    WHAT? Seriously? When did that happen?
  8. Fred Abse
    Fred Abse Guest
    I was confusing them with Burr Brown.
    They appear to be one of the few remaining independents.
    Sorry,pardon.
  9. Joerg
    Joerg Guest
    Whew. Don't give us such as scare again this early in the morning :)
    TI swallowed a lot of companies. Burr-Brown, Unitrode, and then National
    Semiconductor. I hope there won't be much more consolidation because
    that reduces our options. Or at least if there is, then there should be
    new players coming up.
  10. Fred Abse
    Fred Abse Guest
    LTspice handles quite a few syntaxes (syntaces?) that aren't in the manual.
    The nice thing about standards is that there are so many to choose from...
  11. Joerg
    Joerg Guest
    I think syntaxes is right. But it sound too much like sin taxes.
  12. Fred Abse
    Fred Abse Guest
    Only in certain counties in Nevada...
  13. Guest
    I received a reply from Analog Devices
    "I think we can acknowledge the error in the model. I will have the engineer that created the model fix the error
    and have the corrected version up on the web within the week."
  14. RobertMacy
    RobertMacy Guest
    Did you send an email to Alex Bordodynov?
  15. wanderer
    wanderer Guest
    I received the new AD8218.cir file. I haven't tried it yet. It should be onthe ADI website within the next week or so.
    * AD8218 SPICE Macro-model
    * Description: Current Shunt Monitor, high side current sensing
    * Generic Desc: 4.0V to 80V operation, 8S6DPTMRNJIX
    * Developed by: DK
    * Revision History:
    * 1.0 (9/2012) - DK - initial release
    * 2.0 (8/2013) - PB - modified gain of voltages on VREF to output from 2x to 1x
    * Copyright 2012 by Analog Devices, Inc.
    * Refer to http://www.analog.com/Analog_Root/s...nTools/spiceModels/license/spice_general.html
    * for License Statement. Use of this model indicates your acceptance
    * of the terms and provisions in the License Statement.
    * Not Modeled:
    * Temperature effects
    * PSRR vs Frequency
    * Parameters modeled include:
    * CMRR vs Frequency
    * VOS (RTI)
    * Bandwidth
    * Gain Error
    * Voltage Spectral Noise: 110nV/rt hz at 1kHz
    * Output Impedance: 2 ohms
    * Slew Rate
    * Common Mode Range: 4.0V to 80V
    * END Notes
    * Maximum output voltage limited to 5.2V
    * Node Assignments
    * noninverting input
    * | inverting input
    * | | Vs
    * | | | ref
    * | | | | enable
    * | | | | | ground
    * | | | | | | output
    ..SUBCKT AD8218 +IN -IN VS REF ENB GND OUT
    *** Input Stage ***
    EV 99 0 Value={ IF( V(VS) <4, V(+IN) , IF( V(VS) > 5.5, V(+IN), V(VS) )) }
    Q1 3 1 7. 0 NPN
    Q2 4 2 8 0 NPN
    R1 99 3 1129
    R2 99 4 1129
    R3 7. 9 1e3
    R4 8 9 1e3
    I1 9 GND 400E-6
    Ibp +IN GND 124E-6
    Ibn -IN GND 124E-6
    *** Input and Feedback Resistors ***
    EOS 5 1 poly(1) (201,GND) 0 -1
    R9 5 +IN 75e3
    R10 REF 5 1.5e6
    R11 -IN 2 75.045e3
    R12 20 2 1.5e6
    *** 1st Stage ***
    D1 100 6 DZENER2
    G1 100 10 1 2 .001
    D2 10 6 DZENER1
    R8 10 100 200e3
    *** 2nd Stage ***
    G2 100 20 10 100 .005
    R7 20 100 1E6
    C1 20 100 11.68E-9
    *** Internal Reference ***
    E1 100 0 7 0 1
    R5 99 7 100e3
    R6 7 GND 100e3
    **** zero-pole stage
    *G4 100 30 20 100 .59e-6
    G4 100 30 20 100 .588e-6
    R14 30 35 1e6
    R16 35 100 1.7e6
    L1 30 35 .65
    **** 1st pole stage
    G3 100 40 30 100 1e-6
    R13 40 100 1E6
    C2 40 100 186e-15
    **** 2nd pole stage
    G5 100 45 40 100 1e-6
    R15 45 100 1E6
    C3 45 100 186e-15
    *C3 45 100 1e-15
    *** Spectral Noise ***
    VN GND 190 .65
    DN 190 200 DNOISE
    RN 200 GND 1
    VM GND 200 0
    FN GND 201 VM 1
    RZ 201 GND 1
    *** CMRR ***
    *GCMR 500 0 505 0 .3e-9
    *RCMR 500 501 1e6
    *LCMR 501 0 80
    RCM1 500 501 549e6
    LCMR 500 501 80
    RCM2 501 0 1e6
    GCM2 600 0 500 0 .85e-6
    RCM3 600 0 1e6
    CCM2 600 0 655e-15
    RCMR1 +IN 505 10e6
    RCMR2 505 -IN 10e6
    *** Clamp
    *D3 11 20 Dlow
    D3 11 20 D
    V7 11 0 0
    D4 20 12 D
    V8 +IN 12 .722
    *** Output Stage ***
    EAVG AVG GND Value={ ((V(+IN) + V(-IN))*0.5 )}
    E02 65 0 Value={ IF( V(AVG) > 80, 5.2 , IF( V(AVG) < 4.0, 0, V(45))) }
    E03 70 0 Value={ IF( V(ENB) == 0, V(65) + V(600) + .08, IF( V(ENB) != 0, V(65) + V(600), V(65) + V(600) )) }
    E04 75 0 Value={ IF( V(70) > 5.2, 5.2 , IF( V(70) < 5.2, V(70)-.00491, V(70) )) }
    *** Output Resistance
    *Rout 70 OUT 2
    Rout 75 OUT 2
    *** Output Current limiting
    Et 71 0 70 OUT 20
    Qc 45 71 72 0 NPN
    Re 72 0 10
    ..model D D
    *.model Dlow D(Rdon=0 Rdoff=1e6 Vfwd=0.7)
    *.model Dlow D(Ron=0 Roff=1e6 Vf=0.7)
    ..MODEL DZENER1 D(BV=2V, IS=1E-14, IBV=1E-3)
    ..MODEL DZENER2 D(BV=2V, IS=1E-14, IBV=1E-3)
    ..MODEL DNOISE D(AF=0, KF=0.0195e-10.5)
    ..model DILIM D(IS=1E-15)
    ..model NPN NPN
    ..end
  16. Fred Abse
    Fred Abse Guest
    A quick play with LTspice shows it works. I've not dug deep, yet, but, at
    least the offset pin works like it should (and didn't with AD's model).
    More later, when I've had a proper look.
  17. Fred Abse
    Fred Abse Guest
    No, they didn't. I had to add a couple of 1T resistors to their subckt, to
    allow floating VS and ENB, to clear Spice warnings..
    Your model shows more overshoot, and ringing, on 10mV pulse input, than
    the ADI model.
    I don't think much of the pulse generator it seems they used to measure
    rise time (datasheet fig.11, green trace). >100ns rise? Yecch!
  18. Fred Abse
    Fred Abse Guest
    Better than the previous one.
    Needs ".ends", not ".end"
    Add to input stage:
    *Allow VS and ENB to be floated
    Rvsfloat VS GND 1T
    Renbfloat ENB GND 1T
    Gain error versus tempearture is stairstepped.
  19. Fred Abse
    Fred Abse Guest
    Yeah true, but for laboratory characterization?
    I don't think I I've ever had a pulse generator that bad ;-)
  20. Fred Abse
    Fred Abse Guest
    Doesn't change much, AFAICS.
    Comparison posted to a.b.s.e.
