AD624AD alternative wanted.
Discussion in 'General Electronics Discussion' started by bigone5500, Feb 20, 2015.
  1. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Is there a cheaper alternative? I am trying to build an ECG monitor.
  2. Harald Kapp
    11,313
    2,593
    The AD624 is a precision instrumentation amplifier. You wil find a few similar parts when you look on the websites of the usual suspects (Analog Devices, Texas Instruments, Linear Technology to name but a few).
    No other amplifier will be an exact second source for the AD624. Some parameters will always differ. You will have to know, for your application, which are the relevant parameters and which ones can be relaxed. Only then will you be able to find a replacement - not necessarily a less expensive one.
    You will also have to verify the performance of the circuit with another amplifier rather thorouhgly.
  3. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
    Thanks harald. I will probably go ahead and get the AD624AD anyway.
  4. bigone5500
    bigone5500
    712
    120
    Apr 9, 2014
  5. Harald Kapp
    11,313
    2,593
    The AD624 is an instrumentation amplifier, the LM324 is an operational amplifier. These are different kinds of amplifier. You can build your own instrumentation amplifier from 3 operational amplifiers, but you will be hard pressed to achieve the accuracy that comes with an integrated instrumentaion amplifier that has been tuned and tested in the factory.
  6. mofy
    mofy
    46
    14
    Dec 19, 2014
    The AD624 is probably worth the money because of the integrated resistors, boosts the CMRR a lot!
