tkellylord
- Sep 29, 2010
- 10
- Joined
- Sep 29, 2010
- Messages
- 10
Hi all,
i'm test rigging a generator I am designing. Based on theories of electromagnetic induction and harvests small amounts of energy over a long period to hopefully charge your phone (fingers crossed).
I've worked out that I gain approximatley 22mA every second with an average voltage of 1.5v. The device will charge for approx 6 hours.
I wanted to find roughly how much i could charge my phone. I've tried to work it out but not 100% this is write. If you have a second could you please check over this...
coulombs = amps X time(seconds)
And 1 ampere hour = 3600 coulombs
A phone battery that is 1400 mAh or 1.4A/h equates to 5040 coulombs. so in total it needs 5040 coulombs of electricty passing into the battery in order to charge it. That means for a 6 hour charge we need to have 5040 coulombs of electricity delivered in a 6 hour period, therefore we need 5040coulombs/the number of seconds in 6 hours
5040/(6 x 60 x 60) = 0.233 amps second.
so if the average current was to be 22mA or 0.022A then we could accumulate 0.022 x 6 x 60 x 60 coulombs = 475.2. Using the 1400mAh phone battery as a reference the the phone could operate at this capacity for 5.657 minutes.( 5040/60 = 84 coulombs/minute).
If the phone uses 5Watts of power at 3.7 volts, that gives 1.35 amps.................5.86 minutes of full use. ((3600 x 1.35)/60) = 81 and 475.2/81 = 5.86 minutes
thanks if you could check
Tom
Tom
