actuator with reverse polarity switch
Discussion in 'Sensors and Actuators' started by cat5, Jan 6, 2013.
  1. cat5
    cat5
    Jan 6, 2013
    I am trying to wire a 12 volt actuator that will extend and retract triggered by a limit switch to activate the circuit. I am considering wiring it similar to a vehicle door lock switch. The problem I'm not sure about is whether the actuator will automatically retract after making contact with a straight hinge micro limit switch. Will this retract the actuator fully or will it just go far enough back to open the limit switch? Is there another way I can make this work? I need the actuator to extend and then retract by itself.
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Some actuators fully retract via a spring others don't retract at all until you reverse polarity, it really depends on the actuator and the design of the circuit...
