R2 should not be connected to the piezo as shown. It should be connected between V+ and the 555 Trigger Pin 2.
C6 isn't doing anything more than creating a current surge when the Output pin goes high and low. You need a resistor between the 555 output pin3 and the junction of C6 & R4 to create a time constant ramp, if that's what you want..
The 386 data sheet indicates a capacitor (where you have R6) when configured as an amplifier.
Chris
1. Not sure I follow, isn't this setup the same as what you drew in
this only with the coupling cap added?
2. I see now what you mean. The way this is setup the discharge goes back through the 555 and to ground but when there was just a switch there before and that switch was released the discharge had nowhere else to go but through the white noise circuit. But I don't really see why a resistor should be added, wouldn't the diode that duke37 suggested in that position be better? Or perhaps you have another reason for that resistor? Maybe they should both be added?
3. Yes, but then I saw some schematics that used a resistance instead and the way I understood it the polarized cap works in pretty much the same way by adding resistance when it's loaded, but I may have misunderstood this completely. As I said, I'm quite new to all of this, so please enlighten me
EDIT: I've read up more on this and I see now why it should be a cap of around 10 uF instead. I think i mixed it up with the possibility of adding a resistor in series with that cap to control the amount of gain between 20 (nothing between pins 1 and 8) to 200 (cap between them, overriding the inner resistor of the 555).
Thanx again for your input guys!
