Activate a relay using laptop's parallel port
Discussion in 'General Electronics Discussion' started by hrgwea, Apr 13, 2011.
  1. hrgwea
    hrgwea
    Apr 13, 2011
    Hi, guys. I'm new here. Forgiveme if this is too newbie.
    I have a relay that I want to switch on using one of the output pins on the parallel port.
    This is what I've got:
    [​IMG]
    The relay is powered by a 5V DC adapter and the transistor should act as a switch.
    But i dont know where to connect the parallel port's ground pin.
    If I just connect the 5V pin to the transistor's base (like the diagram shows), it doesn't work.
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Ground to emitter/-5V. Add base resistor (value depends on port, transistor, & relay data).
  3. hrgwea
    hrgwea
    Apr 13, 2011
    It works. Thanks.
