Accuracy of radio/GPS-like system?
Discussion in 'Electronic Basics' started by Wildepad, Oct 8, 2005.
  1. Wildepad
    Wildepad Guest
    How accurate could something like this be:
    Three antennae on ten foot towers are set up about 100 yards apart.
    A handheld unit, no larger than about eight inches square and an inch
    or so thick, uses signals from those to determine its position within
    the triangle (the unit will usually be held fairly parallel to the
    ground, rarely at greater than a 45 degree angle).
    Now it can't just figure out it's basic spot but also what angle it is
    to a baseline -- that is, it isn't enough to say that it's 83 feet
    from tower #1, 212 feet from tower #2, etc., it also has to read out
    that it is 18.42 degrees to the line between towers 1 and 2.
    In other words, on a map with the towers plotted, it must be possible
    to determine exactly where the unit is _and_ where it is pointing.
    'Absolute' accuracy is not as important as repeatable and relational
    accuracy -- that is, it can read 83 feet from tower #1 when it is
    actually 82.4 feet, as long as it always reads the same thing at that
    point and it reads 41.5 feet from that tower when it is exactly half
    as far away (when it is actually 41.2 feet away). ((Does that make
    sense?))
    The complete unit has to be no more than $1500, and the towers with
    transmitters no more than $500 each (these do not have to be
    weatherproof -- they will be taken down after each day's use -- pipe
    towers whose 'feet' slip into pipes driven into the ground are
    probably best).
    What accuracy could be reasonably reached?
    Within a yard, within a foot, within an 1/8 of an inch?
    Perhaps more importantly, what accuracy in the direction it's pointing
    could be reached? (i.e. if there were two such units, and you plotted
    their readings on a map in a computer, could you determine whether
    laser pointers attached to them will cross 250 yards outside the
    triangle?)
    Any constructive answers appreciated.
  2. Jasen Betts
    Jasen Betts Guest
    it needs to knows how far off the ground it is, or it needs a fourth
    transmitter.
    that depends how close they are to each other.
    differential GPS will give you centimetre precision (or better) with just
    one tower. - should be uner $1000 for the tower.
    angle is harder to do, I know there are inertial angle sensors
    I have no idea of their cost, precision or operating requirements.
    Bye.
    Jasen
  3. Wildepad
    Wildepad Guest
    Thanks for that info. Unfortunately, ground height will be changing,
    so I guess a fourth tower will be necessary.
    The readings will be in clumps -- 80 to 100 possible readings within a
    foot or two of each other, then another 80-100 a few yards away, then
    another . . . and they all hae to relate to one another.
    Basically, the entire interior of the triangle (now a square?) will be
    covered.
    Sigh! The angle is the really important part -- position is
    meaningless unless the exact direction is included.
    Thanks!
  4. Richard
    Richard Guest
    If you know the position (lat/lon) of the fixed location and of the point
    you are located, you can compute the angle.
    1. Determine delta lat and delta lon between the two points (it helps to
    read latitude and longitude as decimals, or convert them to decimals)
    2. Find atan(delta lat/delta lon) to get the angle from the fixed point.
    If using Excel, this will be the angle in radians, so convert to degrees by
    multiplying by 180/pi.
    Making a triangle, delta lat is the y-axis distance from the fixed point to
    the new location; delta lon is the y-axis difference. Thus, you can see that
    Pythagoras comes to aid once again.
    I hope this helps (and that my trig is still accurate).
    Richard
  5. Wildepad
    Wildepad Guest
    I need to compute the angle of the device relative to a line, not what
    angle it is from its position to another point.
    This device (#1) would be attached to a device (#2) which is acquiring
    other data. #1's readings would be used to orient #2's data when
    constructing a 3-D map. Since it is perfectly possible for what #2 is
    measuring to have great discontinuities, and even be rotated at
    strange angles from sampling position to sampling position, it would
    fall to the readings from #1 to provide an accurate reference not only
    of position within a triangle but also of the data's angle relative to
    a baseline.
  6. Richard
    Richard Guest
    From what I understand, you wnat to know the direction your device is
    pointing.
    How about a 2- or 3-axis compass co-located with your roving positioning
    unit (GPS)? The GPS would provide your position and the compass would
    provide the direction you are pointing your device.
    See http://www.pnicorp.com/. I have used their TCM series units. Great for
    pitch and roll info (which you probably don't need), as well as direction.
    Richard
  7. Wildepad
    Wildepad Guest
    The problem with those is resolution.
    iirc, the affordable ones only provide about 2 degrees of accuracy.
    For this app, I need an order of magnitude better than that.
  8. ehsjr
    ehsjr Guest
    How about determining the angle optically instead of with
    the GPS? A laser pointer and protractor can give you the
    relative angle from the handheld unit to each of the antennas.
    But your description of the angle needed is incomplete. A point
    can't have an angle with respect to a line. For example:
    HandHeld_Unit
    A-------------------------------------------------B
    What is the angle of the hand held to the line defined
    by points A and B?
    You need to define a second line in order to find an angle.
    Ed
  9. I think you misunderstand the angle that he wants.
    He has a line drawn on the handheld device (or perhaps a laser beam
    projecting from it), and wants to know the angle between that line (or
    the laser beam) and your A/B line.
    To get the orientation of the device, he will need a compass or
    something of similar function in the device.
  10. Wildepad
    Wildepad Guest
    This has to be accurate to about 1/4 degree, and the reading has to be
    taken within about the second that the unit can be held steady.
    The handheld unit isn't a mathematical point, it's an eight inch
    square. As such, it has a front edge which is the 'second line'.
    Thanks for responding!
  11. Wildepad
    Wildepad Guest
    I hope not. I was thinking about two receivers in the device, their
    antennae at opposite corners of the unit. The difference in their
    location should (I hope) provide the angle in relation to a baseline.
    Orientation to something outside the triangle (or square) is
    unnecessary (for the mapping process, it doesn't matter which way is
    north).
  12. Richard
    Richard Guest
    "Wildepad" <noreplies> wrote in message
    After several days, we have determined that you really want angular
    measurament accuracy, but $700 is too expensive (TCM2.5 compass) to achieve
    0.1 degree accuracy because it busts the budget for the entire system.
    You state you want to determine the angle to the straight line that connects
    two towers. You do, of course, realize that every point on that line is at a
    different horizontal angle from your roving unit. Are you asking to
    determine the angle that a beam will intersect the line? If so, a compass
    tied to each unit still may be your best bet.
    Other alternatives (some may border on the ridiculous):
    - Make the "pointers" long enough so there is a definite position
    difference between the from and back; mount a GPS unit on each end and
    compute the angle between their positions (expensive).
    - Mount one or more accelerometers in the units (at the end closest to the
    beam output) then, starting with the units pointing in a known direction
    (you need to know what that direction is), the data from the
    accelerometer(s) could be used to determine speed and direction of movement.
    Compute angular difference from the starting point. Using one accelerometer
    for horizontal movement and one for vertical movement, you will be able to
    determine both the geographical point of intersection and the altitude of
    intersection.
    The above would require some way to obtain and process the data. The units
    could be hardwired to a controller unit or, that being impractical, you
    could use a wireless system (Bluetooth, etc.).
    Assuming the line runs east-west, if your two units are inside the triangle
    (south of the line) and the beams bisect the line at any angle between 0.1
    and 89.9 degrees for the left-most unit and 359.9 and 269.9 degrees for the
    right-most unit, you can be sure the beams will intersect at some point if
    the units are at the same height and vertically pointing at the same angle.
    The intersection point will be determined by the positions of the two roving
    units and the angle they are pointing. Distance between the units and
    distance to the line both come into play. Trig will, once again, be useful
    in determining where they will intersect.
    If I still don't understand what you are trying to do, maybe you could be a
    bit more specific about what you are trying to accomplish and seeing if the
    folks in this group can give you other ideas of how to do it.
    Accuracy can be expensive. Don't get discouraged, just research as many
    alternatives as possible.
    Good luck, no matter how you end up approaching this.
    Richard
    Old guy; perpetual student
  13. Rich Grise
    Rich Grise Guest
    Put two loop antennas on the handheld, set the transmitters at the
    towers to three different frequencies, and have three receivers
    in the box, which can resolve the relative phase of the two loop
    antennas' signals (quadrature detector?); this will give you relative
    angles to the three towers, then just trig it out.
    With just radio, there's no way to determine distance, unless you're
    using some kind of radar. But angles are simple, with two loops. (at
    90 degrees to each other of course.)
    Good Luck!
    Rich
  14. Wildepad
    Wildepad Guest
    The problem now looks like neither radio nor sound would be accurate
    enough -- neither one can go much below 3cm at any cost, which is far
    too coarse for positioning, let alone determining the angle.
    Maybe that's why no one else is trying it? :)
    Thanks for the input!
  15. ehsjr
    ehsjr Guest
    Throw in the towel. You need accuracy of +/- 15 minutes and the
    unit will be held by a human, not mounted on a pivot and locked
    in place, even if momentarily? Seems like a non-starter. I think
    you need to re-define the problem, or the approach. Heck, GPS
    won't give you that kind of accuracy, forgetting the other issues.
    Ed
  16. Jasen Betts
    Jasen Betts Guest
    He wants to know which way the handheld unit is pointing WRT some baseline.
    they look parallel to me :)
  17. Jasen Betts
    Jasen Betts Guest
    the only problem I see with this is that the operator holding the device
    will distort the readings.
  18. ehsjr
    ehsjr Guest
    Yup. And you can't solve that problem until "handheld unit" is
    given some detail. For example, which way is the handheld unit
    shown below pointing with respect to the baseline below it?
    | Hand |
    | Held |
    | Unit |
    -------------------------------------------- baseline
    As it turns out, the closer you question him, the more detail
    comes out. Originally, the handheld unit was "about eight inches
    square". Now he says it is a square which removes some ambiguity,
    and the second line is the front edge of the square, removing the
    remqaining ambiguity. And he adds that he needs accuracy to
    about 1/4 degree.
    Really? They look perpendicular to me. Let me draw and extend
    the edge line for you:
    |HandHeld_Unit|
    The details are important! His original description
    was mathematically equivalent to a point and a line.
    We can assume anything we want - and be completely
    wrong - until he specifies the ambiguity out of the
    question. Hell, his reference line on the handheld unit
    could have been either diagonal of (what turned out to be)
    a square.
    Ed
  19. Wildepad
    Wildepad Guest
    Um, what part of "square" is missing from "eight inches square"?
    What difference could that possibly make? Pick a straight line --
    front edge, side, diagonal, whatever -- as long as you don't change
    what is defining the orientation of the unit between readings, how the
    'angle of the unit' changes relative to the baseline at consecutive
    readings is being acquired.
    I was asking what accuracy is possible. Adding that I need 1/4 degree
    expresses my disappointment at there not being anything readily
    available.
    You added four different lines, completely changing the situation!
    The orientation of the text, which is how you originally represented
    the unit, is parallel to the A-B line.
    But if you want to consider that the orientation of the unit is
    determined by the side, fine -- it can't possibly matter since such
    information is only used when determining how the angle has changed
    between readings.
    Um, no, it wasn't. I described a three dimensional object -- width and
    length (eight inches square) and height.
  20. Wildepad
    Wildepad Guest
    Just because something is handheld does not prevent it from being held
    solidly up against something when readings are taken.
