LearningSomethingToday
- Mar 4, 2018
- 23
- Joined
- Mar 4, 2018
- Messages
- 23
If I am working on a differential amp circuit that uses a 27volt Zener diode and resistor to form a voltage reference what would be the acceptable deviation from 27 volts? The circuit I am looking at is consistently putting out 25.42 volts. I am not sure if a simple Zener regulator like this has some acceptable error or tolerance. When Zeners are failing do they typically go open,short or sway away from their intended values?
Thank you!
Thank you!
