G
Gordon
My outboard boat engine has an AC auxillary output for onboard 12 volt
use (so the manual states), however I have noticed the voltage varies
between 8 and 19 volts AC depending on idle to full revs. As most of
my boating is with low engine revs I am concerned that I'll never
reach 14.7 volts DC (after AC to DC)for battery charging.
So I am considering stepping-up the AC using a transformer and then
using a voltage regulator to limit the DC to 14.7V accepting that the
available current will be reduced.
Two questions:
1) Is there a smarter way of doing this?
if not, then
2)How well would a standard 50Hz transformer perform over a frequency
range of 25 to 250Hz? I'm considering a 115V to 240V converting
transformer for this.
Any help would be gratefully received!
Regards,
Gordon Jago.
Two questions:
if not, then
Regards,
Gordon Jago.
