AC Voltage Reference
Discussion in 'Electronic Design' started by Mio, Dec 22, 2008.
  1. Mio
    Mio Guest
    Hello all,
    I'm trying to think of a good way to get a precise AC voltage (224VAC)
    out of line voltage.
    Thus far, I've thought of the following options:
    Use a decent DC power supply, and buy an inverter. From the inverter,
    use a 120/224 transformer (I can wind this myself) From what I saw,
    most cheap inverters have crappy voltage regulation, though.
    Use a decent DC power supply, and build an inverter. I've never built
    an inverter, but I understand the theory behind them.
    Use a constant voltage transformer, and hook it up to a 240/224
    transformer. CVTs seem very expensive, though. So I don't really like
    this.
    Use something like an ac/ac chopper motor drive, sample voltage and
    adjust the regulator with a microcontroller or comparator. I'm the
    least sure about this method.
    I'm looking for +-1%. Any other ideas? Any of these really stupid?
  2. Mio
    Mio Guest
    I forgot to mention anything about power.
    Basically, this gets hooked up to a transformer, rectified, filtered,
    voltage divided, and sampled by a microcontroller.
  3. So the power requirement is quite low?
    How about:
    signal generator -> power amp -> transformer run backwards.
    I don't know if you can rely on a normal audio power amp to have gain
    constant to 1% - but I expect others here do. Otherwise you could make
    something, look for high power opamps etc.
  4. Phil Allison
    Phil Allison Guest
    "Mio"
    ** So you are going for a world's record in pointless and futile circuit
    design ?
    This loon would have to be the Google Groper fuckwit of the year.
    ...... Phil
  5. Huh?
    What's the point in doing all that?
    What are you actually trying to do/achieve?
    Dave.
  6. Mio
    Mio Guest
    We swap out components pretty often, and have to recalibrate based on
    the differences in transformers/resistors/diodes/etc. As our line
    voltage can vary by a lot, I was just trying to think of an easy way
    to do the recalibration.
  7. Phil Allison
    Phil Allison Guest
    the differences in transformers/resistors/diodes/etc.As our line
    ** Makes absolutely no sense whatsoever.
    Surely you can measure the mains voltage at any time and calibrate your
    device based on that reading.
    Be aware the mains voltage is not a very good sine wave so the peak and rms
    values are not precisely related by the sq.rt of 2.
    ...... Phil
  8. Charles
    Charles Guest
    AC to DC and then DC to AC via an inverter, with a tight feedback loop based
    on a stable reference.
  9. Jamie
    Jamie Guest
    Variac ?
    You can get a motorized type to have it controlled to maintain voltage.
    That's about as simple as it gets..
    http://webpages.charter.net/jamie_5"
  10. Guest
    Hey, year's not over yet.
  11. Jasen Betts
    Jasen Betts Guest
    here's another:
    on-line sine-wave UPS followed by a step-up transformer
    or better, a 230V sine-wave on-line UPS followed by a
    230V to 224V autotransformer (can be made from a 230 to 6V transofmer)
  12. Jasen Betts
    Jasen Betts Guest
    just uase a variac, dial up 224V and then do your measurements.
    if you see frequent voltage fluctuations you may need to add an alarm
    to warn you when it needs readjustment.
  13. Rich Grise
    Rich Grise Guest
    Of course! Googles NEVER like the right answer - I think that's why they
    resort to googlegroups.
    If you think buying a CVT off the shelf is expensive, just add up all of
    the costs of inventing any other of those schemes.
    Good Luck!
    Rich
