S
Serpent
to put frankly, im a sorta-beginner when it comes to electronics
my problem is that a circuit i found in a book is for an ac to dc
power supply..the setup is relatively simple, and winds up with 3
outputs (+, -, and ground, although not an output) with two
potentiometers leading to the pos. and neg. output..
my question is why the circuit would require two potentiometers to
control the flow..it seems to me like the circuit should have one
potentiometer attached to the neg. output..
sorry if the question is unanswerable without seeing the circuit, im
tryin to setup my scanner to help work around that
thanks for any response
