LKO Railroad
- Aug 9, 2013
- 43
- Joined
- Aug 9, 2013
- Messages
- 43
No. The PNP transistor at the bottom is schematically upside down. The 1K collector resistor of the same device should be connected to -15V as should the end of the 10K resistor that currently goes to ground. It would help future de-bugging if you could put indent's on each of the components in your schematic i.e. R1, Q1, C1, IC1a etc.Do I have it drawn correctly?
[mod note: image shown in post rather than as a pdf file]
Looks OK now. As I said previously, build it up and set to work a section at a time. As I found very early on in my electronics life, building a circuit in one hit is fraught with problems. If it fails t work, where do you start? whereas when doing it a section at a time, if the next bit added stop it working properly, you know which bit to investigate. Finally, don't connect the FETs until you are satisfied the rest of it is working properly.
