Jim Thompson
I have a load, which is a lamp of 240V and 50W, I need 2 sensor to drive it.
Both sensors are 240V powered and output is 240V.
How do I create an OR gate for this AC driven device so that if any one of
the sensor is triggered, the lamp will light up? I can't join both output
together as it will blown by the back fire if one output is high (240V) and
the other is OFF.
Appreciate if you could send your suggestion to [email protected] as I
seldom have access to newsgroup..thanks
Use a relay on each "sensor" output... parallel the poles to get the
"OR" function.
...Jim Thompson
