Hi
I have a little project where i need to transmit about 1.5kw over 500m into a rectifier and then into an inverter for power generation (to reduce volt drop)
input voltage is about 230v ish
my idea was to step up to about 1000v and step down again to around 200v
i have 10mm SWA allready available in the ground
any ideas if this can be done low cost ?? and if so where i could get the components
Thanks D
Thanks D
