I have a trolling motor to which I'm hooking up a Pulse Width Modulator. I have installed plugs meant for DC purposes, but am not happy with them. These plugs use a solder connection to wire, which has failed twice already. I'd rather screw a wire down than solder it. Furthermore, the plugs are a real pain to separate. The system has a voltage of 12V and a max draw of 29A. I'd like to set the system up with AC jacks and plugs, since these will not have the aforementioned problems. I see that most AC plugs are rated for 15A and 125V. My purpose would use less power overall and less voltage, but would still send significantly more amperage through the plug. Is this a problem, or can I use AC jacks/plugs? Thanks.
Categories
Platforms
Content
