Ac Electric motor
Discussion in 'Power Electronics' started by Hayz, Sep 27, 2021.
  1. Hayz
    Hayz
    3
    Sep 27, 2021
    Hello guys
    I have an ac 240v electric motor with 3 wires coming from the windings.
    Yellow, Orange and blue.
    I would like to convert same to a sander. How should i use these wires to power the motor without causing any harm.??
    I know nothing about motors.
    Thanks in advance.
    Hayz
  2. Minder
    Minder
    3,120
    673
    Apr 24, 2015
    Check the winding resistance, you most likely have a common point and possibly two different resistance values for each winding, you will need a start capacitor to connect in series with the highest value winding, do you know if it has a start switch?
    What is the HP and RPM?
  3. Bluejets
    Bluejets
    5,037
    1,052
    Oct 5, 2014
  4. Hayz
    Hayz
    3
    Sep 27, 2021
    ..it came from a washing machine.
    Will check the rpm asap.
  5. Minder
    Minder
    3,120
    673
    Apr 24, 2015
    If you know the model of the W.M. it came from, you may be able to find the Capacitor value needed for the start winding.From a manual on the WEB.
    Hayz likes this.
  6. Hayz
    Hayz
    3
    Sep 27, 2021
    Thanks..
    I will have another look at it...many thanks
