AC Circuit Problem HELP. Urgent.
Discussion in 'Electronics Homework Help' started by Finnjamin, May 12, 2016.
  1. Finnjamin
    Finnjamin
    May 12, 2016
    Hi There.
    I wonder if anyone could help me with the problem I have. I have spent quite a lot of time researching how one should go about doing this problem, however, as of this far, I am still not even close to getting anywhere...
    This problem is part of some Homework I have for an Electronics course i do at UCT.
    I will post an attached photo of the problem.
  2. davenn
    davenn Moderator
    13,833
    1,950
    hi there
    welcome
    so what have you learnt in class so far that you can use to make a start on this problem ?
  3. Alec_t
    Alec_t
    2,956
    803
    Jul 7, 2015
    Post you attempts so far, so that we can give guidance.
  4. Finnjamin
    Finnjamin
    May 12, 2016
    Hi. Thanks for much for the quick responses. I will tell you what i think i am meant to do and where i am stuck at the moment.
    What i think i need to do is calculate the Z thevinin and the V thevinin, and then the current would be Vth/Zth. Which i can then input the different constraints for I that are given to work out the different values of Z2. (Because the equations for Zth and Vth will both include Z2) . My issue at the moment is I do not know how to work out Vth with the extra current source in the middle there.
    Let me know what you think.
    Thanks so much!
  5. Ratch
    Ratch
    1,094
    334
    Mar 10, 2013
    Looks like no one but I is going to help you. First you need to get up to speed on the PIT (Port Immittance Theorem). You can find out about that is the link below.
    https://www.electronicspoint.com/threads/output-resistance-of-equivalent-op-amp-circuit.278977/ Now look at the attachment below. We first find the transfer function Vo/Vs . Then setting the denominator to zero, we find the -ZL . That is your Thevenin impedance look back from ZL. You can go on from there. I also substituted the parameter values into the Thevenin impedance. Hopefully, I did not make a mistake. Ask if you have any questions.
    Ratch
  6. The Electrician
    The Electrician
    116
    11
    Jul 6, 2012
    Since the OP said his request for help was urgent, and posted last Thursday, I suspect the due date has passed, and we probably won't hear from him again.
    But, Finnjamin, just in case you see this, would you post the answer here?
    davenn likes this.
