AC adaptor polarity
D
Darren
Hi
I have purchased a Chess computer over the internet that requires 9v 300ma,
centre positive.
It is coming without an ac adaptor.
I have a couple of old adaptors that are 9v 300ma but there are no polarity
markings.
A know only a little about electronics, although I only use my multimeter to
test my rechargeable batteries usually.
Apart from checking for smoke..., how can I determine the polarity of the
adaptor.
Also, am I better off spending a little more and just buying an adaptor that
is regulated? The chess computer is extremely expensive to replace and I
don't want to risk it.
Darren
T
Tom Biasi
Darren said:
Hi
300ma,
centre positive.
polarity
markings.
to
adaptor.
that
Darren
OK,
You have observed enough to see that it takes 9v @300mA. with a center
positive.
Can't you use your multimeter to see if the center is positive with respect
to the ring?
If you can check batteries you can do this. If the MM is digital, and you
put the positive lead in the center and the negative lead on the ring you
should see a plus voltage. If the meter has a minus sign in front of the
reading the polarity is wrong. With the power off, make sure the plug fits
the unit also.
Regards,
Tom
D
Darren
Thanks Tom.
That all made sense and I tried it, finding that:
I have one adapter that is centre negative (not suitable for this
application)
and one adapter that is centre positive (suitable for this application).
I did find however that this 9v adaptor is putting out 13.3v.
I'm not sure if the circuitry of the chess computer will have some for of
protection to allow for that fluctuation.
Do you think I should get a regulated adaptor? (When the chess computer
arrives.)
or
Wait until the thing arrives and there may be some information about voltage
tolerances?
or
Not be concerned about this extra voltage.
(The adaptor's 50hz too if that info. is of any use.)
Thanks again.
Sincerely
Darren
It was actually for a
L
Lord Garth
Darren said:
Thanks Tom.
application)
arrives.)
<snip>
Load the supply to 300mA and measure the output voltage....
If fact, load it a little more and see what you get.
I would think that a regulated supply would be better. You can
build one quite easily should you wish.
D
Darren
Thanks Lord Garth
That's a little beyond me at the moment I'm afraid.
How would I load it? With a light bulb? Resistor?
I'll have to check the math etc. as it's been a long time. E=I*R (amps =
volts * resistance?)
Then attach the contacts of the multimeter as before?
Sorry I'm not that educated on the issue.
I'll get there eventually.
Thanks again.
Dumby Darren
R
Roger Johansson
If you know that the original power supply was un-regulated there is no
reason to get one now. An unregulated adapter with the same data will
work fine.
You can measure the voltage of a battery, you say.
When you do that, can you see a polarity indicator on the display?
Can you see a difference if you shift the probe leads, does it show a
minus sign if you put the probes on backward?
If you can see this, you know how to find the plus contact on a
battery, and that is marked on the battery too, so you can check that
your DMM works as it should. You will know after trying this that the
red probe lead is the one you should use on the plus side. If you
shift the leads you get negative voltage values.
Now you should be confident enough to measure the voltage that comes
from the new adaptor, and find out what polarity it has.
In practical terms you may have to find a piece of wire you can insert
into the contact, because the probe will not get into the contact.
Anyway, you fix the mechanical contact with both the inner and outer
metal in the contact, and measure the voltage and polarity.
If it needs changing you can cut the cable and connect it again, with
the other polarity.
When you measure the voltage of an unregulated adaptor without a load
you will get a significantly higher voltage, like 16-19 Volt, and this
is nothing to worry about as long as both the voltage and the current
is the same as on the original adapter.
If this chess computer is very important to you you could, of course
get a regulated supply, and test it before connecting it. That would
remove this possible source of error: If the adapter is made for much
higher current it will give higher voltage when loaded too light. If
also the power supply circuits of the computer are really badly
designed this could cause some problems. Very unlikely but not
completely impossible.
D
Darren
Thanks Roger.
Cutting and swapping the cable would fix the polarity issue.
Yes the mm has a polarity indicator and I've cleared that up now.
And now it becomes apparent to me that the voltage would be higher when the
adaptor's not under load.
Perhaps a regulated adapter would be safest as the chess unit is 600 Aust.
dollars to replace or 300 to import. (Big profit margin.)
I will try and find out the spec's of the original adaptor perhaps too.
(Reg/unreg.)
Thanks group. You've been extremely helpful.
Darren.
L
Lord Garth
Darren said:
Thanks Lord Garth
You're going to need a power resistor to load the supply. You have E=I*R
so rearrange the equation for R since that is what you want to find. R=E/I
You are going to be playing with R so you don't have to be exact.
R=14V/.350A R is about 40 ohms, lower values will increase the current.
The power dissipated by the resistor will be P=I*E P=.350A*14V P=4.9W
use a 10W resistor and don't burn yourself!
You can build a regulated 9 volt supply most easily by obtaining an LM7809
three terminal regulator. A couple of small capacitors wouldn't hurt
either.
Page 6 from this pdf shows you how to connect the regulator:
http://www.datasheetcatalog.com/datasheets_pdf/L/M/7/8/LM7809.shtml
You will need to bolt the regulator onto a heat sink which you can scavenge
from
a broken power supply or simply cut up an aluminum can.
You test the current by placing the meter leads in series with the load
resistor.
Don't forget to plug the test leads into the correct socket and set the
meter to
its highest current range. The power supply + output connects to the load
resistor,
the other side of the load resistor connects to the meter - lead. The meter
+ lead
then returns to the supply -. + to - to + to - in series....for current.
To measure
the output voltage, the meter, reset for volts is placed across the supply
output +
to + an - to - in parallel.
R
Roger Johansson
when the adaptor's not under load.
Aust. dollars to replace or 300 to import. (Big profit margin.)
Another option is to get an unregulated supply with voltage switch, so
it can be set to positions marked 3V 6V 7.2V 9V 12V.
With such a supply you can safely start at a low voltage, connect
the computer with correct polarity, step up one step at a time, until
the machine works as it should. I have used that several times.
Then I fix the switch with tape and use it for that device.
These stepped but unregulated adapters are much cheaper than regulated
supplies.
Another idea is to build a regulated power supply yourself.
You need an npn power transistor which can handle 300mA and a few watts
power.
Connect the collector to the output of an unregulated supply, the
emitter becomes your new regulated output, the base we lock at 9.6
Volt, because the emitter will always be 0.6 Volt lower than the base,
so we get 9V out if the base is kept at 9.6V.
We can use a resistor and a 9.6V zener diode to fix the base at the
right voltage.
Jerry R
Darren said:
Thanks Lord Garth
Darrren, that should be: E=I*R ( volts = amps * resistance)
....jerry
D
Darren
Oops that's right Jerry. Thanks.
Thankyou for all the advice gang. I feel confident I have all I need.
I shall now put your advice into practice.
Darren
You all deserve a pat on the back and pe
