ac adaptor output 9v -1A to 12v-1.5A
Discussion in 'Electronics Homework Help' started by viao101, Oct 16, 2011.
  1. viao101
    viao101
    4
    Oct 16, 2011
    for safety pre-caution
    my modem AC ADAPTOR don't work anymore
    input: 220V-50Hz
    output: 9V-1A
    i wanna know if i could use the two other AC Adaptor
    i have at home with
    input: 100-240V-50-60Hz 0.5A max
    output: 12v- 1.5A
    And
    input: 100-240V-50\60Hz. 0.6A
    output: 12v-1.5A
  2. viao101
    viao101
    4
    Oct 16, 2011
    input: 220V-50Hz
    output: 9V-1A
    i have at home with
    output: 12v- 1.5A
    And
    output: 12v-1.5A
  3. Externet
    Externet
    775
    168
    Aug 24, 2009
    You did not specify if the original/spare adapters output DC or AC !
    Highly likely, the modem works with 5V DC internally. The defunct adapter is converted by circuitry in the modem to produce the 5VDC it needs.
    Chances are good to swap it with your spares; IF the defunct adapter was not killed by a failure in the modem.
  4. viao101
    viao101
    4
    Oct 16, 2011
    both the original and spare are AC
  5. (*steve*)
    25,499
    2,839
    Maybe.
    Maybe not.
    Both adapters are effectively equivalent.
    Without more information (preferably in less threads) I can;t be more precise.
    edit: Threads merged.
    edit2: I'd give you something more than 50/50 that the other adapters would work (and if they do it may run somewhat hotter). They will almost certainly either work or damage the modem. No likely third option.
  6. viao101
    viao101
    4
    Oct 16, 2011
    thanx for the help guys
    i do appreciate it!!!!!
Similar Threads
Loading...
