about numeric keyboard questions?
Discussion in 'Electronic Basics' started by nick, Feb 21, 2004.
  1. nick
    nick Guest
    i use many diodes to make a numeric keybord , total are 12 keys,the
    keys connect to other ICs when i connect DC9v to this circuit , and
    press the key
    i divcover become less 9v but the ic need 9v to operate , Are the keys
    make potential difference in the circut how to solve this problem, to
    provide a stable voltage to the circuit when i press the keys?
    thanks
  2. the Wiz
    the Wiz Guest
    There is a voltage drop across each diode that is in the circuit when a key is
    pressed, typically from 0.2 to 0.6 volts depending on the type of diode.
    More about me: http://www.jecarter.com/
    VB3/VB6/C/PowerBasic source code: http://www.jecarter.com/programs.html
    Freeware for the Palm with NS Basic source code: http://nsb.jecarter.com
    Drivers for Pablo graphics tablet and JamCam cameras: http://home.earthlink.net/~mwbt/
    johnecarter [email protected] mindspring dot.dot com. Fix the obvious to reply by email.
