ABout laptop adapter/charger
Discussion in 'General Electronics Discussion' started by sitopons, Feb 13, 2010.
  1. sitopons
    sitopons
    3
    Feb 13, 2010
    My charger is fried and was wondering if it can be fixed or it is way too complicated...also, I found this charger on the net for 10 bucks but the characteristics are a bit different...The one I have is 19 V 4.74 A , and the one they selling is 19 V 3.42 A ...does that make a difference ,will it damage the laptop ?
    :confused:
  2. (*steve*)
    25,500
    2,840
    It probably won't damage the laptop, but it might damage the charger.
    The replacement can not supply the same current as the original. This means it may be overloaded.
    All is not lost though. The charger is rated to power the laptop *and* charge the battery. If you're only doing one of these, the charger will probably be fine.
    I would advise charging the battery in the laptop with the laptop off before powering up the laptop. Alternatively, you could use the laptop without the battery fitted.
    Be aware that if your laptop is a Dell, it may refuse to charge the batter if you connect a non-Dell power supply. I'm not sure if other manufactures pull this stupid trick, but beware.
