about hFE multimeter test...
Discussion in 'Beginner Electronics' started by ArameFarpado, Apr 19, 2008.
  1. ArameFarpado
    ArameFarpado Guest
    Hi all...
    a transistor "BD435" is giving me 440 in hFE test on the multimeter, when
    the tecnical data i've found tell me min=40 max=475...
    does this mean the transistor is really in good shape?
    can it be busted and still give a good hFE test result on the multimeter?
    thanks
    ArameFarpado
  2. Baron
    Baron Guest
    It means it is within spec !
  3. ArameFarpado
    ArameFarpado Guest
    Em Sábado, 19 de Abril de 2008 20:18, Brian Gregory [UK] escreveu:
    connecting just E and C in the socket, it reads the same value for hFE.
    so, it got me thinking that hFE measure is not a transistor test for
    working/burned transistor...
    do you use hFE measure to see if a transistor is busted?
    thanks
    ArameFarpado
