A Transformer Sink???
R
Randy Gross
I am probably wearing out my welcome with volley after volley of ceaseless
questions. While on a path, and a new door opens, I have to pursue the
adventure. I have one more question then I promise to give you men a break.
It concerns the addition of heat sinks mounted to the transformer core.
Something different I know. Question is: How much will this affect the
inductance.
Please view in a fixed-width font such as Courier.
| | | | | | The sinks are light Ga. aluminum
| | | | | | bent into a U shape and then
|__| |__| |__|
______ _______________________ ______ applied to a bed of
______|| ||______ thermal compound. The
______ | | ______ entire assembly is then
______|| Transformer ||______ strapped to the tranny
______ | | ______ with enough nylon straps
______|| ||______ to hold them securely.
|_______________________|
I am not suggesting continuos duty, just slow down the temperature rise for
a few more moments of operation between sprints.
I look at your opinions seriously or I would not ask. Go or No Go is all I
need.
K
Kevin Aylward
ceaseless questions. While on a path, and a new door opens, I have to
pursue the adventure. I have one more question then I promise to give
you men a break.
core. Something different I know. Question is: How much will this
affect the inductance.
It won't. Aluminum is non-magetic. Even if the heatsink were magnetic,
it wont effect the turns ratio.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
R
Randy Gross
That is good news Mr. Aylward, there may be some hope yet for the lowly
MOT.
Randy Gross
<[email protected]>...
: Randy Gross wrote:
: > I am probably wearing out my welcome with volley after volley of
: > ceaseless questions. While on a path, and a new door opens, I have to
: > pursue the adventure. I have one more question then I promise to give
: > you men a break.
: > It concerns the addition of heat sinks mounted to the transformer
: > core. Something different I know. Question is: How much will this
: > affect the inductance.
: It won't. Aluminum is non-magetic. Even if the heatsink were magnetic,
: it wont effect the turns ratio.
: Kevin Aylward
: [email protected]
: http://www.anasoft.co.uk
: SuperSpice, a very affordable Mixed-Mode
: Windows Simulator with Schematic Capture,
: Waveform Display, FFT's and Filter Design.
John Popelish
inductance.
|__| |__| |__|
need.
There is only two ways any external metal will have any negative
impact on a transformer. One would be if it made good electrical
contact with the laminations in more than one place, such that it
allowed the laminations to form a shorted turn winding around the core
flux, which would act as an additional load on the transformer. The
other would be if the metal, itself, somehow surrounded the core flux,
creating a shorted turn on the transformer. This is sometimes a
problem with mounting hardware that passes through the center hole of
a toroidal transformer.
The fins you describe should do neither.
R
Randy Gross
<Snip>
: There is only two ways any external metal will have any negative
: impact on a transformer. One would be if it made good electrical
: contact with the laminations in more than one place, such that it
: allowed the laminations to form a shorted turn winding around the core
: flux, which would act as an additional load on the transformer.
This is the effect that concerned me the most. I read somewhere that the
varnish used to stabilize transformers is formulated to sink heat to the
outer surface of the unit. This is where the Idea came from to sink the
tranny, assist the varnish to wick away the heat. Providing there's no
adverse reaction from the thermal compound, the laminations should remain
independent.
Randy Gross
:The other would be if the metal, itself, somehow surrounded the core flux,
: creating a shorted turn on the transformer. This is sometimes a
: problem with mounting hardware that passes through the center hole of
: a toroidal transformer.
: The fins you describe should do neither.
: John Popelish
