A thermistor problem.
Discussion in 'General Electronics Discussion' started by Shyamal796, Mar 25, 2012.
  1. Shyamal796
    Shyamal796
    32
    Mar 19, 2012
    I want to know in which process, i can use a thermistor with 741 op amp. How a thermistor work?
  2. davenn
    davenn Moderator
    13,657
    1,888
    Depends on what you are trying to achieve??
    A common use would be to set the op-amp up as a comparator where one input would be held at a reference voltage and the thermistor and a resistor acting as a voltage divider would be connected to the other input so that a changing temperature would cause a change in resistance of the thermistor and hence a change in voltage at that input
    So what are you wanting to do ?
    Cheers
  3. Harald Kapp
    10,395
    2,271
    Also important: What kind of thermistor? PTC or NTC?
    You could also try to build a thermometer, although you are likely to run ino some issues with linearity.
    While your approach is interesting and even good hacking style: The engineering approach is not "I have a part, what can I do with it", but the other way round: "I have a problem, which part will help me solve it?".
    Harald
  4. davenn
    davenn Moderator
    13,657
    1,888
    Good additional thoughts Harald. :) let's see what sort of response we get so he can be guided along the trail.
  5. Shyamal796
    Shyamal796
    32
    Mar 19, 2012
    Sorry sir, i'm not hacker.
  6. (*steve*)
    25,412
    2,780
    What does this mean?
  7. Harald Kapp
    10,395
    2,271
    When I used "hacking style" I didn't mean to offend you.
    Hacking is used in at least two different ways, "bad" and "good".
    One is related to illegal activities as in computer hacking (http://en.wikipedia.org/wiki/Hacking).
    A second meaning is related to using and modifying existing things for other purposes as e.g. here: http://www.hackaday.com/
    My answer referred to the latter, "good" hacking.
    Sorry I didn't express that clearly in my first answer.
    Harald
