I suggest you make sure that they are.I am not sure that all those grounds are connected together
If you are referring to the various points in your circuit that are marked as grounds then yes, they all connect to the negative rail. That rail also has to connect to the guitar ground and the Fender ground.wherever it says Ground, I run a wire from that connection to the negative rail.
