D
David Nebenzahl
[email protected] spake thus:
Nope. No way could it work.
What you say is correct, I'm guessing, for what goes on on the *primary*
side of the xfmr. But on the secondary side, as someone else pointed out
here, there's no way the split secondary windings are going to be able
to selectively pick up only that part of the magnetic flux intended for
that channel. In other words, the secondary can only act as one winding
(albeit one split in half), so, as someone also pointed out, what you
end up with is a stereo amp with crosstalk: 100% crosstalk.
Just as McDonald's is where you go when you're hungry but don't really
care about the quality of your food, Wikipedia is where you go when
you're curious but don't really care about the quality of your knowledge.
- Matthew White's WikiWatch (http://users.erols.com/mwhite28/wikiwoo.htm)
I have never seen such a design, I didn't see a link to the pic, so I
am flying by the seat of my pants here.
First of all such a thing might be stereo, or hi fidelity, but not
both. To explain, my definition of stereo is that there are two
seperate, discreet and identical channels. Perhaps is is very high
fidelity when used as a mono amp, but actually was capable of stereo.
Using a large main output transformer for the mono signal, typical push
pull, but the if the primaries are split up and phased just right I can
see how this can be accomplished. Of course then you have the
secondaries of the small transformer in series with the secondaries of
the big transformer. The way I see it, the arraingment of the primaries
is important, otherwise you get alot of second harmonic distortion, IMO
an unacceptable level.
The only way this can work is to feed L+R to the 6L6s in differential
mode, and the L-R in common mode. By splitting the primaries so that
the differential mode current is bucked effectively in the primaries of
the secondary output transformer, and the common mode current is
doubled, acceptable performance could be achieved IMO.
