In general about transformers: They are usually very tough fellows!
The rated power (VA, not Watt), voltage and current of a transformer are referring to a max. continuous load on the secondary side at a specified temperature (often 40°C).
That load can without problems be exceeded by great factors for shorter time (seconds, minutes).
If Miguel Lopez reads this, maybe he also has a formula for overloading transformers...
Basically it has to do with the inner temperature of the transformer and that the isolating materials will not get damaged.
