Pooh Bear said:
And you seem to find that an excuse for playing the crazy loony. Ideas
that are
plain barking mad don't enter the above category.
I just presented an idea and asking others if any one looked into this
..............and it is the ideas that is the mother of all inventions. But a
fool like you will never understand it except farting around and barking on
others idea
Isn't it obvious that your daft 'wind turbine' idea will produce more
energy
sapping drag than the energy it might produce ?
Wrong again. ..... use ya thick brain if you have any .......drag is
already there. Isn't most of the vehicles designed in a way with front
opening to force the air into the radiator ? do you think that opening is
true aerodynamic ? and has no drag ? and effect on vehicales fuel efficiency
? I am sure every one here agrees if we compare a true aerodynamic front
shape vehicales that will give us more milage per gallons vs the one we see
with air intake design. We already compromised few miles efficiency on the
cost of engine cooling cauz the gas is cheap but if you look at the newer
design of the vehicales , they are getting more close to true aerodynamic
shape. My argument here is not to discuss the aerodynamic shape what I am
simply suggesting is the force of air as a bi-product generated by the
movement of vehicale....how to utilise that energy into power ? a simple
thing comes in mind..... wind turbine. ...... can be designed in a way that
the SAME air forced into radiator can be forced again into turbine and in
turn turbine generates extra power to charge the batteries. So what rocket
science or complexity you see here ? Its a simple designe and can be
acheived. I don't see any additional drag on the vehicale. May be it added
another 10-20 lbs as turbine weight but on the other hand we can reduce the
number of batteries carryin on board cauz of additional power generation
capacity in the vehicale. A simple example is turbo charged engine, Its
turbine again that produces extra horse power in engine ?
So, if you think it's a brilliant idea to add cost and complexity ( not to
mention a ludicrous appearance ) in order to reduce overall performance
then I'm
sure you deserve a round of applause.
Grahamou
Yes I do deserve a round of applause cauz atleast I come up with some ideas
...... tell me what ideas you got except fating in this newsgroup ?
You disconnect my idea considering an idiot thought without goin deeper cauz
you think you are the fucking authority whereas I think you are a rusty fat
ass fool who needs retirement from this New Group. We need some fresh blood
and brains here.
Still if you think I am wrong then come on prove it .......
