JosephKK
On Jan 19, 6:37 pm, John Larkin
[....]I still can't get my head around the fundamental reason why there's
only one kind of positive resistor but two kinds of negative resistor.I think I can add to the confusion:We are thinking "number line like this:-3, -2, -1, 0, 1, 2, 3, ..... really big, infinite, -really big ...There are two ways to get to a negative number. One takes you past
the "infinite" value. In truth though. we have a 2D world we can
avoid hitting the singular value by going a little reactive.
As often happens in math, the pole is the center pole of a spiral
staircase. You have to go around the pole twice to get back where you
started.For projective infinity kind of, for affine infinity no.Since we are adding to the confusion:As we consider the impedance values, we are not considering how they
depend on frequency. We can have frequency dependent resistances and
positive and negative reactive values that depend in various ways on
the frequency. This makes it at least a 3 dimensional space.
Now you are making progress. And that 3rd dimension is non-linear and
twisted, it goes through a transition between 300 MHz and 3 GHz where
lumped constants give way to transmission line techniques.
I don't see that as a real transition in the extra dimension. That is
an artifact created by the mechanical sizes we can do. Real
transitions would be the places where the wavelength passes some size
determined by physics.
BTW: We have 60Hz transmission lines near my house so the 300MHz
lower edge on you 300MHz and 3GHz is a little high.
That would require the use of extremely loose and sloppy definition of
transmission line.
