||| There's exactly-Zero 'quantum' =anything= <-edited
||| within physical reality.
| And that's exactly what happend as folks
| in Physics converged into groupwise-in-
| teractive dynamics with respect to Planck's
| Erroneous empirical result 'with respect
| to' the black-body power-spectrum, flying-
| off-the-handle with respect to physical
| reality, as a group -- 'because' "after all",
| they were 'calculating' everything that
| they agreed upon. In 'modern' 'days', all
| of this has literally become entrenched
| as a result of the hijacking of 'science' in
| the name of 'national security' -- which
| has literally coerced folks who want to
| do Science into extraordinarily-cloister-
| ed group-wise interactive dynamics.
| Why does all of this matter?
| To begin to understand that, return to the
| impossibility of increasing TempK with-
| out bounds in a black-body [or in anything
| else within physical reality.]
Saying that "heat-of-vaporization" is a "prop-
erty of an isotope" doesn't say anything
about how and why it's so, and it's how and
why it's so that matters, in particular, with
respect to Physis' having 'flown-off-the-
handle' in the aftermath of the "ultraviolet
catastrophe's" being encountered in the
late-19th-'century'.
'statistical mechanics' and 'thermodynamics'
[which, to date, have both literally embodied
the mean-seeking stuff that I discussed in
my preceding post, doing so in empirical
ways that 'leave-it-at-that' without actually ex-
plaining how and why it's so] view the "vapor-
ization" that is always observed as TempK is
increased 'without-limit' as occurring as a
consequence of 'atoms' exhibiting "vibration"
that increases in both frequency and intens-
ity as TempK is increased, and that 'atoms'
and 'molecules' move with increasing vel-
ocities 'because' they 'bounce-off-of' one
another with increasing-intensity that derives
in the fact that they are "vibrating" relatively-
intensely, or, in the case of accelerator ex-
periments, because imparted-motion is
relatively-large in 'particle'-collisions.
But that doesn't say how and why 'atoms'
and 'molecules' 'vibrate more-intensely' as
TempK increases.
'quantum mechanics' views such increas-
ing-vibrational-intensity as 'being' the re-
sult of so-called "sub-atimic particles"
'jumping-between' so-called "energy lev-
els" 'within' 'atoms'.
'quantum mechanics' 'believes' in the 'ex-
istences' of such 'sub-atomic particles'
because, during the course of experiment-
ation, such as with respect to the photo-
electric effect, Compton 'scattering', 'atomic'-
spectrum-analyses, and in modern 'particle'-
accelerators, there's the =appearance= of
'there being hard, point-like, things within
the target media', that can 'jump-between-
levels' in 'atoms' [corresponding to the
"lines" in line-spectra", and/or be emitted-
by and/or absorbed-within other 'atoms'.
I long-ago worked-through =all= of the ex-
perimental results that were invoked in
ways that 'presumed' that energy 'is quant-
ized', reducing everything in all of them to
=Continuous= energy-flows, but I'll stick
with the black-body stuff in this discussion
because the Continuity-of-energy-flow in
it applies to all of the other experimental
results too -- and one might as well Cor-
rect an Error where the Error first occurred,
which was with respect to the ultraviolet
catastrophe in the late-19th-'century'.
Back in the early-20th-'century', what have
been referred to as "atoms" were viewed
as being 'little solar systems', largely on
the basis of the results of Compton's 'scat-
tering' experiments, in which it was 'pre-
sumed' that incident 'photons' resulted
in the deflection of 'electrons' that were
'orbiting' the 'much-heavier' 'nucleus' of
'atoms' in the target material.
During these experiments, however, it
was also observed that such 'deflections'
were =never= precisely-replicable, occur-
ing, instead, within stereotypically-occur-
ring =ranges= of 'deflection'-angles which
ranges, themselves, had stereotypically-
occurring angular-intensity-variations.
It was in attempts' to explain this observ-
ed 'flexibility' that so-called "randomness"
entered-into calculations that were, short-
ly thereafter, to form the 'foundation' of
what has become 'quantum mechanics'.
It was with respect to observed stuff like
this that Heisenberg posed his so-called
"uncertainty principle", which states that
position and momentum of a 'particle'
cannot be simultaneously-determined, so
stuff like the observed angular-intensity-
variance in the Compton 'scattering' re-
sults could be 'accounted' for.
'uncertainty' marked the beginning of
'quantum weirdness', =all= of which
actually resulted from the fact that folks
'presumed' that energy was 'quantized'
rather than flowing Continuously.
There's no 'easy' way to transition to the
Correct resolution, so I'll just 'jump' to
stating it :-]
That there =must= be =something=
that 'segregates' "matter" into relatively-
'discrete' 'atoms' is obvious in the fact
that there exist 'discrete' "elements",
which, although they can be mixed and
or compounded, can always be purified
again, but not 'purified' beyond their "el-
emental" 'states'. [Their elemental 'states'
can ["of course"] be temporarily 'broken-
down', as occurs in so-called 'nuclear'
"fissions" and "fusions", but the results
of such 'nuclear' reactions are different
elemental 'states' which will segregate
in accord with their newly-transitioned-
into elemental 'states' during 'normal'
chemical reactions.]
Don't the chemical and 'nuclear' dyn-
amics above "require" that there 'be
discrete stuff' that can be so 'mixed-
and-matched"? Because, after all,
although some of the above is relatively-
hard to accomplish, when it is accom-
plished, it routinely occurs in replicable
ways.
Nope.
Continuous flowing of 'just'-energy can,
and does, accomplish everything with-
in physical reality, all in a way that is
Rigorously-Verified by all known exper-
imental results -- the 'only' thing is that
seeing continuous-energy enables one
to do vastly-much-more than can be
accomplished if one 'restricts' what one
'sees' to so-called "discrete particles"
[not in the least, because seeing con-
tinuous-energy Eliminates =all= so-
called "quantum weirdness", in the
process, disclosing that 'quantum
weirdness' never did have any physic-
ally-real existence -- just as Einstein
asserted in his Courageous, Life-
long-unrelenting, stand -- even though
folks who'd jumped-onto the 'quantum'
band-wagon, 'forgetting' that he'd lit-
erally carried Physics forward on his
back, excorciated him 'just' as relent-
lessly.]
What have been referred to as "atoms"
are 'just' quantities of energy 'contained-
within' harmonic compression<->expan-
sion harmonic-interaction with a con-
tinuous energy-surround --
Spherical-Standing-Wave<->Universal-
Energy-Supply harmonics --
SSW<->UES harmonics.
'containment' happens be-cause, dur-
ing some creation violence -- as in a
supernova -- more energy is compressed
'within' a spherical volume of space than
can pass-through the surface-area of that
spherical volume without instantiating
a perpheral spherical 'shell' in which the
energy-pressure surpasses the energy-
pressure that the volume of 'contained'
energy can exert upon its energy-surround.
The main feature of SSW<->UES harmon-
ics is that their compression<->expan-
sion harmonics are nonlinearly-dynamic.
At max-compression, all of the energy is
'contained-within' a volume that is non-
linearly-small relative to the volume of
at max-expansion.
The nonlinearity varies both in volume
per unit 'time' and in 'time', =always=
reflecting the relative-actions of 'intern-
al' and 'external' continuous energy-
pressures.
The nonlinear dynamics exhibit a "U"-
shaped acceleration-curve, with max-
energy-redistribution-velocity 'always'
occurring 'in the middle', of the max-
compression and max-expansion 'states'
Because of the compression and expan-
sion, when other quantities of continuous
energy interact with such an 'atom', how
and why they will interact is completely-
Determined by the in-compression<->
expansion 'phase' of the harmonics.
When an SSW<->UES harmonic is in
a relatively-max-compression 'state',
it will 'appear-to-be' what has been re-
ferred to as an "atomic nucleus", and
it's interactions with 'incoming' energy
of sufficiently-high frequency to fit 'with-
in' the max-compression 'state' will be
commensurately 'point'-like "elastic".
When an SSW is in a relatively-max-
expansion 'state', which is, as above,
itself a "shelling"-compression, it will
'appear', to incoming continuous-energy
having commensurate-frequency 'to-be'
what have been referred to as an "elec-
tron", and experimental observations
will occur accordingly.
In-between max-compression and max-
expansion, analogous continuous-ener-
gy interactive-dynamics occur at relative-
frequencies that 'match' the degree of
compression or expansion that exists
when incident-continuous-energy inter-
acts with the SSW<->UES harmonic.
[Note that the "work functions" and "cut-
off-frequencies" observed in the photo-
electric effect are =Completely= Determ-
ined in the above.]
Also, because the Volume/Surface-Area
ratio of the 'contained' energy varies non-
linearly with compression/expansion
'phase, the 'containment' breaks-down
dynamically either allowing continuous-
energy-flow to be either 'out-of' or 'into'
the SSW<->UES harmonic. Hence the
various elemental "emission" and "ab-
sorption" "line spectra", which are com-
pletely-Determined by the max-expansion
quantity of energy 'contained-within' the
SSW<->UES harmonic -- which is how
and why the line spectra are uniquely-
correlated to the various elements.
Various quantities of energy so 'contained'
have the different properties of the known
elements be-cause their harmonic inter-
actions with their energy-surrounds is
Completely-Determined in their energy-
contents.
All of this happens via =continuous= en-
ergy-exchange between the 'contained'
energy and its energy-surround, and
all of this happens in =Exact=, Contin-
uous accord with the Continuous one-
way universal flowing of energy, from
order to disorder, that is what's =described=
by 2nd Thermo [WDB2T], which physically-
real Continuous energy-flow is what un-
derpins the observed expansion of the
Universe.
So-called "radioactivity" =does not= occur
in a 'random' way.
SSW<->UES harmonics dis-integrate
when, and to the degree that, their rel-
atively-local 'containing' UES-energy-
density decreases below that which is,
as above, required to 'maintain contain-
ment'.
When 'atomic' dis-integration, energy
is permanently 'released' from it's former
'containment', which bolsters the energy-
density of the surrounding UES, 'prevent-
ing' further local SSW<->UES did-inte-
grations, which, further, is how and why
'atomic'-dis-integration 'events' have the
=appearance= of 'being random'.
As the Universe continues its Continuous
overall expansion, relatively-more 'atomic'
dis-integrations will occur with respect to
particular elements that 'live-on-the-edge-
of-being-containable' at any 'point' during
the overall universal-expansion dynamics.
That's "the short story" on Tapered Harmony,
which is a "therory of everything" that occurs
Tapered Harmony goes on and on, reduc-
ing everything to the SSW<->UES harmon-
ics that I've briefly discussed above. All ex-
perimental results that I know of are com-
pletely-integrated in TH -- and TH opens-
up an entire 'new-world' in which stuff
that has not even been conceived of before
is rendered flat-out Possible.
I've been discussing TH online over the
course of more than 15 'years', and al-
though, yes, I've received a lot of 'flak' for
doing so, I've =never= received a single
response with respect to anything that's
in TH in any specifically-negatively-crit-
ical way.
There'll =never= be any such stuff that can
be sustained -- be-cause, as is my routine
way, I Proved 100% of TH before I ever 'bo-
thered' anyone with it's stuff.
Albert Einstein was Correct in his Courageous
stand.
"God doesn't play at dice with the universe."
All there is is energy, flowing-Continuously,
Completely-Determined, everywhere within
physical reality, in which there is exactly-Zero
'quantum' anything.
'fire'-at-will, folks.
All that'll happen is that you'll learn TH.
k. p. collins
