A little help here
Discussion in 'Electronic Design' started by [email protected], Sep 22, 2006.
  1. Guest
    Hey, I was wondering if it was possible to connect a phone to the
    computer to use as a microphone ? Ya know, a regular house phone . I've
    connected the phone to one of the lines and am lost as to what to do
    next if this feat is even possible.
    KK
  2. ian field
    ian field Guest
    If you mean a reasonably modern phone, most use an electret mic just like in
    the mics sold to plug into a soundcard.
    Just rip the electret insert out the handset and wire a 2k2 resistor in
    series and a 10uF cap to the join between the two, you need a 3.5mm stereo
    type jack - I think the signal goes to the tip, the +5 to the middle and the
    body is GND, all the info is on the net so you'd best check the details, I
    may have the signal and +5 the wrong way round!!!
  3. Eeyore
    Eeyore Guest
    You don't even need the external bits ( R and C ).
    Some soundblasters mic imputs are wired differently to generic cards AIUI btw.
    Graham
  4. Klem
    Klem Guest
    I did some DJ work for an internet radio station and had people
    calling in. I made a cable with 3.5 mm plug on one end and 2 rca
    plugs on the other. By using the headset feature I plugged in the mic
    signal to the input of the mixer and used one of the out channels to
    go back to the phone. I think added a blocking cap on the voice side
    of the cable as this cordless phone was made for an condenser mic as
    many headsets have, but did not want to feed the dc portion ito the
    mixer
    I now could talk thru the phone by means of the DJ microphones and
    hear people talking to me thru my headset hooked up to the mixer.
    I could make calls and receive calls and control the volume on the
    mixer.
    Just a few cents here
    -K
  5. ruleworld
    ruleworld Guest
  6. Rich Grise
    Rich Grise Guest
    For the amount of time and money it would take to do this sensibly, you'd
    be better off to just pop down to Radio Shack and pick up a microphone
    for about $2.95.
    Have Fun!
    Rich
  7. Or the dollar store. Clip on, stick on goes right on the monitor.
    _____ _ _
    |_ _| | | | |
    | | __ _ _ __ ___ | |__| | ___ _ __ ___ ___ _ __
    | | / _` | '_ ` _ \ | __ |/ _ \| '_ ` _ \ / _ \ '__|
    _| |_ | (_| | | | | | | | | | | (_) | | | | | | __/ |
    |_____| \__,_|_| |_| |_| |_| |_|\___/|_| |_| |_|\___|_|
    __ ____
    / _| | _ \
    ___ | |_ | |_) | ___ _ __ __ _
    / _ \| _| | _ < / _ \| '__/ _` |
    | (_) | | | |_) | (_) | | | (_| |_
    \___/|_| |____/ \___/|_| \__, (_)
    __/ |
    |___/
  8. ian field
    ian field Guest
    Good point - but sometimes its more fun to play with the electronics and
    make something useful with parts from something that was about to go in the
    bin.
  9. Donate it to a teacher. Some like to let their kids dismantle things to see
    what is inside them.
    _____ _ _
    |_ _| | | | |
    __ ____
    / _| | _ \
    __/ |
    |___/
