A little extra knowledge required...
Discussion in 'Electronic Repair' started by Binky, May 25, 2004.
  1. Binky
    Binky Guest
    I posted earlier (about 3 weeks ago) regarding the route into a Panasonic
    NV-EX1B camcorder to a particular section in order to effect a repair. It
    was a bit of a tall order expecting someone to know but it was always worth
    a try.
    I'm now left with a working EX1B that still needs the rear door assembly
    replacing (the new part I have already), but have acquired some knowledge as
    to how the rest of it comes apart and I'm now quite confident to remove the
    bits from all six 'faces'. What I need now is that little bit of extra
    knowledge to guide me to the next area to unscrew and dis-assemble. I have
    exploded parts diagrams, but I'm not sure what to look for after I've
    removed all the obvious and easy bits.
    Is there a book or website or anything really that can point me in the right
    direction? It's a fun experiment that has now become a bit of a challenge.
    If anyone does have the same unit and parts sheets, it's part 33 'rear door'
    on the mechanical parts list. So far I have only one screw left over, had no
    shocks & broken only one ribbon cable connecter....
    Here's hoping......
    Mike.
