A Funny Thing Happened on the way to this circuit
Discussion in 'General Electronics Discussion' started by SparkyCal, May 18, 2020.
  1. SparkyCal
    SparkyCal
    235
    8
    Mar 11, 2020
    I created a circuit that utilizes a 555 timer that flashes a bank of blue LEDs driven by a 12 volt battery
    It works fine. Then I had the bright idea, of creating another bank of LEDs- this time using a yellow LED, and daisy chaining it to the prior LED bank, in series..
    My thought was, it would simply cause both banks of LEDs to blink.
    But I am finding that it is either one or the other. Both banks will not blink at the same time.
    I am sure there is some sort of principle I am not understanding, and violating. Can someone give me a clue?
    Thank-you
  2. bertus
    bertus Moderator
    702
    244
    Nov 8, 2019
    Hello,
    As always, when you have a question, post the schematic.
    Can you draw a schematic of the set-up?
    Bertus
    narkeleptk likes this.
  3. SparkyCal
    SparkyCal
    235
    8
    Mar 11, 2020
    I can't draw a schematic yet, but this is what i can do. Here is the circuit I am working with:(see attached. )
    I also hand drew the LED banks and their connections.
  4. bertus
    bertus Moderator
    702
    244
    Nov 8, 2019
    Hello,
    Do you have the specifications of the leds?
    When the leds do not need serial resistors, aka 12 Volt leds, they should light at the same time.
    It is not a good idee to put classic leds parallel.
    A classic blue led would need 3 to 3.5 Volts to work.
    A classic yellow led would need 2 to 2,5 Volts to work.
    Bertus
  5. SparkyCal
    SparkyCal
    235
    8
    Mar 11, 2020
    Yes I do Bertus. The blue LEDs are 3.oV-3,4V 20mA. the yellow are 1.8V-2.4V 30 mA.
  6. bertus
    bertus Moderator
    702
    244
    Nov 8, 2019
  7. SparkyCal
    SparkyCal
    235
    8
    Mar 11, 2020
    Thank-you. i think you nailed the problem. I failed to realize I was working these banks of LE Ds in parallel. I had assumed, it was i. series. But your observation makes perfect sense. A few solutions are now becoming apparent. Thank-yopu
  8. Bluejets
    Bluejets
    4,062
    848
    Oct 5, 2014
    Just be aware the 555 has a maximum current limit of around 200mA.
  9. SparkyCal
    SparkyCal
    235
    8
    Mar 11, 2020
    Thanks. I have reconsidered this and decided not to introduce a second bank of LEDS. But I learned something from this, do thanks for that,
  10. Nanren888
    Nanren888
    248
    50
    Nov 8, 2015
    BTW, did you have one resistor per LED bank, or one shared?
    As mentioned, one per LED is best.
  11. Bluejets
    Bluejets
    4,062
    848
    Oct 5, 2014
    When you get in to high power LED's , constant current /voltage drivers can be an advantage.
  12. Martaine2005
    Martaine2005
    2,777
    745
    May 12, 2015
    LEDs can be connected either series, parallel or a combination of both depending on the circuit and voltage available.
    There is a great resource section on this forum here , that will explain all you need to know about LEDs.
    Martin
  13. Martaine2005
    Martaine2005
    2,777
    745
    May 12, 2015
    BTW, top is series and bottom is parallel.
    No need to ever ‘assume’ again.
    Martin
  14. Audioguru
    Audioguru
    2,843
    637
    Sep 24, 2016
    My cheap Chinese flashlight has 24 white LEDs in parallel and it works fine. All the LEDs must have been tested and grouped into groups having only one matching forward voltage. The forward voltage is about 3.2V and if a few 2V red LEDs were additionally in parallel then the red ones would light up VERY brightly and the white LEDs would not conduct and produce no light.
