A/D conversion - pic18f4550
Discussion in 'Microcontrollers, Programming and IoT' started by Jack41, Nov 2, 2015.
  1. Jack41
    Jack41
    5
    Nov 2, 2015
    Hello
    I'm trying to make an A/D conversion and I am trying to adapt this code for a PIC18F4550 in MPLAB IDE, but I’m having troubles. I’m programming in C and trying to read the value of a sensor on AN0. How can I adapt this code for my needs?
    Code:
    #include <xc.h>
    #include <stdio.h>
    #include "lcd.h"
    #endif
    int main(void){
        int x;
        int v;
        char d[10];
      __delay_ms(2000);
        ADCON0=0b00000001;
        ADCON1=0b00001110;
        ADCON2=0b10011110;
       Lcd8_Config(&PORTE,&PORTD,2,1,0,7,6,5,4,3,2,1,0);
       Lcd8_Init(&PORTE,&PORTD);
        TRISD=0x00;
        TRISB=0x0F;
        __delay_ms(10);
        lcd_init();
        while(1)
            ADCON0.GO_DONE=1;
            while(ADCON0.GODONE);
            tensaohum=((ADRESH<<8)+ ADRES1)* 4.88;
            inttostr(v,d);
            strcat(d,"mV");
            lcd8_out(2,4,d);
            delay_ms(10);
  2. Harald Kapp
    11,310
    2,588
    Which troubles? Please explain.
    What are your needs?
  3. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    Also your ADCON2 reg will need the correct values for the sys. clock you are using if different from the original code.
    M.
