John
1) I know you can only put two wires in a breaker that is designed for it;
but do they say they can hold two, or do they say they can only hold one;
which way does it work? If it can hold only one, I can just still use
two circuits in one breaker with a jumper, can't I? (I have two outdoor
outlets on their own circuits. One has never been used, and the other just
has some low voltage lighting on it and a few christmas lights in season.
Since I need some space in the panel, it seems reasonable to consolidate
them. If I can't use the jumper, I guess I will just abandon the unused
outlet; but that seems wrong somehow.)
2) Do GFCI breakers require power before you can set them on, like GFCI
outlets? I have a circuit that is flaky, and everything but the GFCI
breaker seems okay. When I swapped the breaker with a spare, it is okay, so
I figure it must be the breaker. It will stay in the on position when
disconnected; does that mean it is bad? The spare is 20a, and it should be
15a, so I need to buy a new one if the old 15a is broken. (I figure the
chances of a 20a breaker being a fire hazzard on a lightly used #14 circuit
for a few days is extremely small, no?)
Thanks.
Thanks.
