a circuit equivalent to function generator
Discussion in 'General Electronics Discussion' started by farrokh, Nov 30, 2015.
  1. farrokh
    farrokh
    9
    Oct 28, 2015
    i want to send a AC current with 20kHz frequncy to a coil. I know that It is possible by a function generator. Because function generator is expensise, i want to do by another thing. how can i do it in inexpensive way?
    Thanks a lot
    Farrokh
  2. BobK
    7,682
    1,689
    Oscillator + audio amplifier.
  3. farrokh
    farrokh
    9
    Oct 28, 2015
    Thank you for your reply,
    I want to use it in metal detector. so it should be light and portable. therefore i think oscillator can't be used, any suggestion?
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    There are many ways of making an oscillator. The simplest I have made uses a CMOS 4093, one resistor and one capacitor. You could also use a blocking oscillator (one transistor and an inductance), a bistable (two transistors) or Wein bridge oscillator (one op-amp).
    I am not up to the latest in metal detectors but the early ones used the search coil in an oscillator which varied in frequency and compared this with a fixed frequency oscillator to give a whistle.
  5. BobK
    7,682
    1,689
    Or a Colpitts oscillator, which has a single transistor, inductor and a few capacitors and resistors.
