(A+B).(A+C) with 3 NANDS and 2 INVERTERS?
Discussion in 'Electronic Basics' started by cae27, Nov 15, 2004.
  1. cae27
    cae27 Guest
    I'm just getting to grips with boolean algebra and I've found a
    problem I can't solve. I'm told I should be able to use Demorgan's
    theorem to convert (A+B).(A+C) into a form using 3 NAND gates and 2
    INVERTERS, but I can't seem to manage it! I should say that this is
    quite new to me so if anyone here can point me in the right direction
    I'd appreciate it, thanks.
    Chris.
  2. Does it have to be (3) NANDs and (2) inverters? Is it okay to use (2) NANDs and
    (1) inverter? (Could use the full complement, but it's not necessary.)
    I'll use / to indicate NOT, + for OR and * for AND:
    (a + b) * (a + c)
    = a * (a + c) + b * (a + c)
    = a*a + a*c + b*a + b*c
    = a*a + a*c + a*b + b*c
    = a*(a + c + b) + b*c
    = a*(1 + c + b) + b*c
    = a*(1) + b*c
    = a + b*c
    Once this is arrived at, try a double NOT to convert the + to an *:
    = //(a + b*C)
    = / ( /a * /(b*c) )
    Rewrite this in function form:
    = /*( /a, /*(b, c) )
    So:
    c -----|\
    | >o----|\
    b -----|/ | >o---->
    a --|>o---'
    For three NANDs and two inverters (if you just have to have the exact number)
    you could just slap them on, like:
    c -----|\
    | >o----|\ ,--|\
    b -----|/ | >o---+ | >o---|>o---->
    a --|>o---'
    Or you could take a different route:
    (a + b) * (a + c)
    = / ( / ( (a + b) * (a + c) ) )
    = / ( ( /(a + b) + /(a + c) ) )
    = / ( ( (/a * /b) + (/a * /c) ) )
    = / ( (/a * /b) + (/a * /c) )
    = /(/a * /b) * /(/a * /c)
    = /*(/a,/b) * /*(/a,/c)
    And wind up with something like this:
    b --|>o----|\
    | >o--,
    a --|>o--+ | >o---|>o---->
    | >o--'
    c --|>o----|/
    Of course, that's (3) NANDs and (4) inverters.
    Jon
  3. Rich Grise
    Rich Grise Guest
    I was gonna start in on you about not giving kids their homework answers,
    but this is a howler! Good Job!
    The first thing I notice about your example is that you're apparently
    using a different part of DeMorgan's stuff than I thought I knew.
    (a + b) - I'd start with this. I'm trying to derive something
    using NANDs, using DeMorgan's Theorem. So I dredge the ol' memory-
    pits, and come up with:
    a + b = /(/a . /b)
    lessee...
    a b a+b /a /b y=/a./b /y
    0 0 0 1 1 1 0
    0 1 1 1 0 0 1
    1 0 1 0 1 0 1
    1 1 1 0 0 0 1
    Yeah, I guess that's it.
    The rest, of course, is left as an exercise for the reader. [Gawd!!
    I _*LOVE*_ saying that!!!!!]
    Rich
  4. Oh, cripes, I left out, in function form:
    = *( /*(/a,/b), /*(/a,/c) )
    = / ( /*( /*(/a,/b), /*(/a,/c) ) )
    And that matches the last diagram I drew.
    Whew!
    Jon
  5. OP did say that they'd been working on it and posted in frustration. Also, I
    usually don't try and provide something that is "bookish" but uses my own way of
    looking at it so they have to stretch a little to get there. If they do, that's
    fine. (Boolean 'algebra' has a lot of similarities with conventional algebra
    taught for finite real numbers. Even the words or phrases, like factor and
    term, come from traditional algebraic usage. De Morgan's is just a unary
    inversion operator and rules for its distribution, I think.)
    Jon
  6. cae27
    cae27 Guest
    Well to be honest it's homework I've set myself, I'm a Physics/Biology
    graduate that find himself in an electrical engineering department
    (and hence involved at some level in electronics, not something I've
    done much of).
    Cheers,
    limewolf.
  7. cae27
    cae27 Guest
    Well, i did post only after trying myself, it's easy when you have
    seen it - thanks for your post it's cleared up my confusion. I think
    most of the problem is down to me not having done anything like this
    for far too long :).
    Thank again,
    limewolf.
  8. hehe. Actually, it's really not too hard and lots of fun once you've learned a
    couple of things. Simple things like the fact that both AND and OR are
    commutative and associative, of course. You can re-derive the rest whenever you
    need it.
    Some things are only slightly sneaky to remember, like:
    (a*/b) + b = a + b
    (a*b) + /b = a + /b
    And keep in mind that 'b' can be some arbitrary factor or term -- it doesn't
    have to be just 'b'. So:
    a*c + a*/b + b*/c = a + b*/c
    You can see this, if it's not already obvious, from:
    a*(c + /b) + b*/c = a + b*/c
    a*(/b + c) + b*/c = a + b*/c
    a*//(/b + c) + b*/c = a + b*/c
    a*/(b*/c) + b*/c = a + b*/c
    then set d= b*/c, giving:
    a*/(d) + d = a + d
    a*/d + d = a + d
    which matches up from earlier.
    Just stick a few things in mind. The rest is just game playing!
    Jon
  9. Rich Grise
    Rich Grise Guest
    OK, fair enough.
    I hope that the rest of my answer was useful for you, because it
    _was_ real, you know. :)
    Rich
