A
alan
Basically, my boss wants me to build a testing system for an IC, which
has an absolute maximum rating of 1.5V to 6.5V VCC.
So my boss wants me to apply some digital signals to the IC and read
some feedback (at up to 20MHz clock). With a variable VCC from 1.5V
to 6.5V (and other features besides, such as being low power). And I
need to be able to apply 1.5V to 6.5V voltage at high, based on my
current VCC.
However the only level shifters I've found are either 1.5V to 5.5V
supply voltages or 4V to very high supply voltages. Nothing quite
fits the 1.5V to 6.5V range.
The best I've managed to come up with is to use a bunch of
(mechanical) relays to select between two level shifters, one for 1.5V
to 5.5V range, the other for 5.5V to 6.5V range. I'm not sure if
solid-state relays will work, because I'm almost sure that the
propagation delay of actual metal is much faster than propagation
delay of semiconductor.
Is this the best solution? Might I have missed a level shifter
capable of reaching the required range?
My controlling device is an FPGA, which can have a VOH of 1.2V, 1.5V,
3.0V and 3.3V (1.5V and 3.3V being the preferred, because our FPGA
prototyping board has only those voltages). The maximum recommended
VIH for the FPGA is 4.1V, with the minimum obviously varying according
to the I/O VCC I select.
Thanks in advance!
current VCC.
Thanks in advance!
