Hello, a newbie here
I salvaged a DC motor from a RC car and wanted to repurpose it by hot glueing it into a pipe and mounting a dust broom into its shaft. Motor runs fine on 9 volt battery but as most of the 9 volt batteries, its voltage starts to gradually drop after 10 seconds all the way to being unable to turn the motor. Tried running it with 4 batteries in parralel with 6 volts. Voltage doesnt drop but not as stong as I'd like it to be and there is not enough clearence to have 6 batteries let alone 4. So I went ahead and bought 9 volt 1 amp adapter to run it directly through the wall. Runs ideally when unmounted but when ı mount something on its shaft it turns fast for a second then comes to a complete halt and turns for what ı assume to be 10 degree, every second. If any Electric savy can help, I would be eternally grateful because it kind of became an honorary matter.
Motor in question is labelled "RC-280SA"
Thank you all in advance.
