(90-660) volt into (0-277) volt power supply
Discussion in 'Power Electronics' started by Henri_deleted, Jun 5, 2014.
Thread Status:
Not open for further replies.
  1. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    Hi folks!
    I would like to know what electronic devices and how I should use to control the voltages between 90 and 660 in order to get between 0-277 (pure SIN)?
    What do you think?[​IMG]
  2. BobK
    7,682
    1,686
    If you have to ask, you should not be doing this.
    Supercap2F and KrisBlueNZ like this.
  3. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    And what is the reason for this?!
  4. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
  5. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    You are so intelligent dude!
  6. BobK
    7,682
    1,686
    Yep, that is why he is still alive after doing a lot of work with electronics. Your question indicates that you might not be so lucky.
    KrisBlueNZ likes this.
  7. (*steve*)
    25,419
    2,790
    The first electronic device you should employ is an engineer.
    He would tell you that your specification is incomplete and would request details.
    Firstly, he would want to know:
    • The input frequency
    • The output frequency
    • The nature of the input voltage (is this an RMS value?
    • The nature of the output voltage (Is this an RMS value?)
    • The maximum output current (or possibly power)
    • The source of the input power
    He would also probably want to know the answer to the question "Why?" because that might prompt other questions, or suggest answers to some of the above.
    Then he would warn you that:
    • The configuration you show is unlikely to be practical, and possibly not even feasible
    • Requiring an output voltage that could be both above and below a wide range of input voltages might entail double conversion
    Then he would sit back and wait for you to answer all his questions before being able to do any more (and that "any more" might be "ask another round of questions").
  8. (*steve*)
    25,419
    2,790
    Oh, and for advice on pure sin, I think that's in another realm of "expertise".
  9. BobK
    7,682
    1,686
    Yes, mostly found in Las Vegas.
  10. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    The details:
    - input and output Frequency == 60 HZ
    - input and output Voltage: RMS
    - Max output current = max of 75 MA
    - The source of the input power: step-down transformer from power plants!
  11. (*steve*)
    25,419
    2,790
    75 MEGA AMPS!!!!! (I'll assume you meant mA (milli-amps).
    So why does the transformer have a variable output from 90 to 660 volts? Surely your mains power is consistent?
    And what are you powering?
  12. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    Yes Steve. That's mili amp. I am not sure if I understood your point well. But, you mean why not using a transformer? Well, it is possible but I need a self-adjuster device to work in a wide range. As for the power consistency, what do you mean by "main power"?!
  13. davenn
    davenn Moderator
    13,674
    1,892
    you haven't really given enough clear info on what you are trying to do
    firstly ... what is the source of the 90-660VAC ?
    and why would it be changing from 90 - 660?
    secondly ... what is being powered by the 0-277 VAC output of the transformer ?
  14. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    Dave!
    the source of 90 to 660 volt AC is power from the network which goes to each unit of the building. (This power supply will be supposed as part of an electricity meter)
    Because, the AC/DC converter that we have on the board accepts the voltages upto 277 volt max.
    I am not sure if I understand your second question but this 0-277 should be converted to DC so the input of the converter is 0-277 volt AC.
    Hope this helps!
  15. davenn
    davenn Moderator
    13,674
    1,892
    neither of those responses make sense ???
    what network ?
    that really doesn't make sense ??
  16. Henri_deleted
    Henri_deleted
    8
    Jun 5, 2014
    What do you mean Dave?
  17. davenn
    davenn Moderator
    13,674
    1,892
    Im closing this thread
    you obviously have no idea what you are doing 'as you were told earlier by some one else GET AN ELECTRICAL ENGINEER
    Some one trained and skilled in dealing with mains power situations
    regards
    (*steve*) likes this.
Thread Status:
