9 + 9 = 18 ?
Discussion in 'Misc Electronics' started by Virginia Belle, Nov 19, 2003.
  1. I Know that this is a dumb question but, I am curious anyway.
    Lets just say that I need an 18 volt DC power source and that the source
    has to come from one of those transformers? that plug into the wall and
    change AC to DC.
    What if I only have two of those transformer devices that are 9 Volts
    DC each.
    Now, If I cut the insulation off of the ends of both of those
    transformers, take the two wire ends from each and twist the 4 ends
    together to make two again, plug them in, will THAT make me the 18 volts
    that I need?
    9 + 9 makes 18 doesn't it?
    PLEASE tell me that I have made SOME sense here?
    Thank You
    Brenda
  2. Rein Wiehler
    Rein Wiehler Guest
    no, that will be 9 volts only.
    you cann cut the connectors of and wire the negative of on 9v adapter
    to the positve of the other adapter. remember you have to "add" the
    voltages
  3. yes, but ONLY THIS WAY:
    source#1 +9V --------------------------------- +18V out
    -9V -----+
    | (connect the wires)
    source#2 +9V -----+
    -9V --------------------------------- GROUND
    HTH fritz
  4. vlad
    vlad Guest
    what i think you are talking about is paralel connection. this would double
    the power but woudlnt increse the voltage.
    you need to make a serial conection. each power adapter has a positive and
    negative wire. you need to connect positive wire
    of one adapter to negative wire of the other.the voltage betven two
    remaining(unconected) wires will be 18.
  5. CWatters
    CWatters Guest
    You need to connect them together in series not paralel.....but first ...
    If the mains adaptor has an earth pin you need to check that neither of the
    output wires is connected to the earth pin.
    If it is connected then you will damage one of the power supplies.
  6. Byron A Jeff
    Byron A Jeff Guest
    -I Know that this is a dumb question but, I am curious anyway.
    -Lets just say that I need an 18 volt DC power source and that the source
    -has to come from one of those transformers?
    A bit more than just a transformer.
    - that plug into the wall and
    -change AC to DC.
    Commonly known as a "wall wart"
    -What if I only have two of those transformer devices that are 9 Volts
    -DC each.
    The you probably have a problem.
    -Now, If I cut the insulation off of the ends of both of those
    -transformers, take the two wire ends from each and twist the 4 ends
    -together to make two again, plug them in, will THAT make me the 18 volts
    -that I need?
    No. It'll most likely blow one or the other of the wall warts depending on
    how you wired it.
    Your best bet is to get the correct supply for what you need. 18V is commonly
    used by laptops so finding such a supply shouldn't be difficult.
    BAJ
