8951 Programming Circuit
Discussion in 'General Electronics Discussion' started by vinit2100, Mar 14, 2014.
  1. vinit2100
    vinit2100
    100
    Oct 21, 2013
    What additional change will happen if i replace DB25 connector with DB9 connector in the attached schematic?
  2. (*steve*)
    25,496
    2,837
    You will have to use different numbered pins, and check to be sure the signal you want to use is available on a DB9 connector (it probably will be, the 15 or so obscure signals are almost never seen these days).
    Is that what you're asking?
