M
Mook Johnson
I'm working on a design that uses an 80c186 with external memory and rom.
While diagnosing i realized something that is strange to an analog inclined
person like myself. The bus is multiplexed using a transparent latch which
makes the the outputs follow the inputs while the LE is high (transparent
part) and latched in the falling edge. (old 373 chip). What I didn't
expect to see was that the AD signals change while the 80c186 ALE is high
and therefore cause glitches on the output of the latch (address bus). The
system works because the setup and hold times for the memories are not
violeted before the read/reite signals are asserted, but it would seem to
add to the EMI produced by the memory bus. This would be solved if the
address was only latched on the negative edge without the transparerent part
when LE is high.
Am I missing something here?
when LE is high.
