Categories
Platforms
Content
Thank you,i read somewere that i can pull out the red and black wires from a USB cable ,is that good or should i buy some USB port for my microcontroller?I bought just the 8051 without any development board .If the current needed is less than 500mA ,
you can power it from a USB PC port.
Still looking at what to buyHow are you going to program 8051?
I am not on a budget ,its that 8051 has the most guides and projects available so far.Probably gonna get one with USB and other stuff included..tho so far i only found the TQFP version and i dont like.Is your 8051 already programmed? Is there more writing on it than a date code and part number?
As far as a programmer goes the 8051 is pretty old. You may have a problem finding one that runs on a USB port. You can spend big bucks and buy a general purpose programmer (best if you can afford it). Or if you are on a budget and want to take the educational cheap route you might be able to build a manual programmer.
Hey,thank you when i mean 8051 i mean the architecture ,so not the programmed version,seomthing like the AT89C51
Thank you for your offer but i need this in the next 2 weeks at most and i live in Europe so delivery will take longer.
Would something like a
http://www.miniinthebox.com/51-scm-...-supports-at89c51-s52-stc89c52_p4027638.html#
work fine for small projects?As far as i see all i need is to place an at89c51 inside it and it will give me basic USB ,reset .
or like this with one already placed inside.
https://www.amazon.co.uk/CY7C68013A...76451530&sr=8-3&keywords=8051+development+kit
Which one you say is better?
If i understood well in the first one i just place the at89c51 and it provides circuits for reset and USB and the second one already has one placed but it comes also with some EEPROM memory?That means that on top of the 4k flash i can use if needed the 64kb EEPROM too?
I dont understand a thing,i know that if i want to run a program on a microcontroller i need to burn it to its ROM or external memory.Do those 2 come with such thing or they offer just power to the microcontroller?So far on my list i have resistors,capacitors,LCD screen,some LED's,different cables ,what i need now is a way to burn the program to the microcontroller.I heard the at89s51 can be burned through serial cable using Keil as burner software?"better" depends on your application.
