8 omhs-4ohms
Discussion in 'General Electronics Discussion' started by cobs, Sep 25, 2012.
  1. cobs
    cobs
    3
    Sep 25, 2012
    Hi guys can anyone please tell me how I can reduce an 8Ohms tweeter to 4Ohms
    Thanks for your help
  2. BobK
    7,682
    1,688
    Why?
  3. cobs
    cobs
    3
    Sep 25, 2012
    Hi yes I will go through a crossover the problem I have is the original tweeter they no longer produce parts for but I have found a voice coil that will fit from the same manufacture
  4. BobK
    7,682
    1,688
    So if I understand you, you are replacing an 4 Ohm tweeter with an 8 Ohm tweeter and the crossover was designed for a 4 Ohm tweeter. You might be able to modify the crossover to use the 8 Ohm tweeter. Do you have a schematic for it?
  5. cobs
    cobs
    3
    Sep 25, 2012
    Hi bobK yes that is correct and no i dont have a schematic
  6. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    Those impedances seem really low for tweeters, they typically range in the 30's to 100 ohm ranges
    that aside, you should be able to use the 8 ohm new ones and just play with the equalizer a little, its going to draw less power than the old ones, so you shouldnt have to worry about breaking the system, it will just be a little quieter, if you are going to do 1 you should probably do the other as well
  7. BobK
    7,682
    1,688
    Well, I don't have any ideas then. The speaker will work, but it won't have the same frequency response as it did before. Have you tried just wiring it in as is?
