8 bit decoder
Discussion in 'Electronic Design' started by [email protected], Feb 15, 2007.
  1. Guest
    hi !
    i am working on a circuit and i need to decode 8 bit binary number to
    show that number to 7 segment BCD display.How can i do that ????
  2. Dave Pollum
    Dave Pollum Guest
    If you want to display BCD data (0 thru 9) on a 7-segment display,
    something like a 7447 or CD4511 (or their modern equivalents) would
    work. For 8-bits, you'll need 2 chips and 2 LED displays. If you
    want to display hexadecimal (0 thru F), check out the Maxim ICM7212 (4
    digits). I found the Maxim part by googling for "7-segment driver".
    HTH
    -Dave Pollum
  3. With a PIC, of course.
    Many thanks,
    Don Lancaster voice phone: (928)428-4073
    Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
    rss: http://www.tinaja.com/whtnu.xml email:
    Please visit my GURU's LAIR web site at http://www.tinaja.com
  4. samiam
    samiam Guest
    I am doing something like this RIGHT NOW on a project I am working on.
    I have two 16L8 PLD's and a table to decode the hex values.
    I split the data bus into two nibbles and feed each to the PLD. The PLD
    outputs drive the seven segments ... works like a charm
  5. Rich Grise
    Rich Grise Guest
    If he wants a BCD display, he'll need three digits to cover the range
    0..255.
    Cheers!
    Rich
  6. Andrew Edge
    Andrew Edge Guest
    Your 7 segment BCD display accepts 4 bits of data.
    You have 8 bits which means you need 2 of them.
    A decoder. Ummmm. You could do without one. Get a 8 BIT Serial IN
    Parallel OUT Shift register Chip. Connect the outputs to your 2 BCD
    display chips.
    You could get the same result by cascading 8 flipflops instead of the
    shift register.
    Andy
  7. cs200939
    cs200939
    7
    Nov 20, 2010
    I am stuck with the same problem.i have constructed a Fibonacci generator and the output is an 8 bit number.i attained this output with the help of two 4 bit binary adders and now i am stuck with the problem of displaying them on two 7 segments displays. Until now ive worked with only 1 7 segment display( i mean i know how to display 0 to 9 but dont know how to display 0 to 99:( ).Can anybody help me with that please.In detail.Thanks
