7912 as negative voltage regulator issue
Discussion in 'General Electronics Discussion' started by Kaash, Aug 16, 2013.
  1. Kaash
    Kaash
    10
    Aug 16, 2013
    hi guys..
    im using 7912 as negative voltage regulator but when i connected it with 12v or 20v supply it got very hot without any output voltage.
    i wasted 4-5 regulators but get no output -12, is there other any way to connect it?
    help plz.
    thanks
  2. BobK
    7,682
    1,688
    You have the ground and power reversed. For a negative regulator the ground has to be higher than the input.
    Edited: You also need the capacitors on the input and output. See the datasheet.
  3. Kaash
    Kaash
    10
    Aug 16, 2013
    will u recommend me capacitor's rating?
  4. BobK
    7,682
    1,688
    Look up the datasheet. It has a sample circuit.
  5. Kaash
    Kaash
    10
    Aug 16, 2013
    ok thanks
