D
DaveC
Hello, Id appreciate comments on the Schematic found here...
http://homepages.paradise.net.nz/ohiro/latch.gif
It's part of a bus I'm designing for a PIC. I wanted to speed things up a
little so I made the WRITE latch capture the value of the last READ
operation. I hope I've done this ok.
Any way I'm still a little up in the air over the AC characteristics of the
75HC573 and need a little clarification.
The part of concern is when PIC READ goes low the Output Control of U2 may
get disabled before U1 is able to latch the data on the 8 bit PIC data I/O
bus. I think the inverter U4A should help? .. Here is how I worked it out.
a) 8ns for U4A + 13ns for U2 OC = 21ns
..vs.
b) 2ns for D1 + 10ns for U1 LE = 12ns
So long as b) is less then a) I should be ok.. or should I replace U4A with
three inverters to be safe.
DaveC
..vs.
DaveC
